S52, now with more snail - Page 4 - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 07-29-2013, 05:26 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
Yeah, I really love using my gasless HF welder. Can't do anything crazy with it, but I've welded some tricycle frames and they've held up fine.
-CJ
Old 07-29-2013, 06:40 PM
cj.surr's Avatar
some kid
Ugh, some annoying realizations today. Went to put in the front struts, and the 96+ strut hats add too much caster, so the non-M control arms don't match up. Alright, I'll just get 95 M3 strut mounts. Nope, also different control arms. OK, I'll just put some non-M strut hats onto the struts and use my existing control arms. Nope, springs are different. Ok, I'll just get some non-M springs and sell the M3 ones. Nope, spring perch on the struts is a different diameter.
Dammit BMW. I don't understand why they couldn't make a single diameter spring for the E36 chassis.
Now I'm looking at buying 96+ M3 control arms or swapping the strut inserts into non-m bodies and getting non-m springs. My control arms are brand new Lemforders. Would hate to give those up. But it seems easier than swapping everything else.
-CJ
Old 07-29-2013, 07:23 PM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
I know that feel bro.
Theres like 4 different brake ducts/ fender linings for the e46.
You'll find something like always
-Dino
Old 07-29-2013, 07:33 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Aluminum is a really great heat conductor (as you now know first hand) and that makes it very challenging to gas weld. Very hard to get the concentrated heat with a torch. Challenge number two is that aluminum oxidizes instantly when exposed to oxygen The alumiweld rods have a chemical coating that supposedly generates a non-oxidizing gas blanket at the weld point but it's so thin that it's not very effective. Just the convection from the heat of welding can carry it away. You can try ghetto heliarc with your HF welder. You need a tank of balloon helium and a nozzle. You aim a flow of helium across the arc from your HF welder and it's a form of heliarc welding. It's not very efficient but for a one time repair it might do the job.....
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 07-29-2013, 07:39 PM
drivinfaster's Avatar
drivinfaster drivinfaster is online now
Mein Auto: rescued bmw's
yeah, i tried the alumiweld rods, too....didn't work too well. brazing may have been easier for me to do.
that being said, it's ok for metal filler i would suppose. it does melt and run (sorta) like solder. i still have a bunch left as i only used maybe 3 rods during my initial attempt with them.
if i ever get feelin kinda crazy, i may just put one of them in my arc welder....
instant puddle of metal, anyone??
most vo-tech schools have a welding program and could probably do the repair for cheap or even free (minus materials), so i would check there as well.
df
Old 07-29-2013, 07:49 PM
cj.surr's Avatar
some kid
Wow, this sounds really ghetto. Even for me!
That way sounds pretty difficult to be honest. I doubt I have enough skill to make a decent weld that way. I emailed a couple welders on craigslist. Hopefully one of them will do it cheap.
df
I'm just not sure how to figure out who to contact at one of those schools?
-CJ
Old 07-29-2013, 08:17 PM
usually one of the instructors will be able to inform you as to how to go about submitting something like that for studdent repair. a lot of times there are forms to fill out regarding liability and damages and such.
df
Old 07-29-2013, 11:06 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Hey CJ, I'm running '95 upper strut mounts on regular non-M control arms with '95 offset FCABs. My geometry is perfect.
1998 BMW 328is
1966 Pontiac GTO
Old 07-30-2013, 02:50 AM
dc_wright's Avatar
Here's a school in Bristol CT. http://www.cttech.org/bristol/techno...ng/welding.htm
Old 07-30-2013, 06:00 AM
cj.surr's Avatar
some kid
Hmm.... Maybe it's because you have offset FCABs? I have centered ones...
-CJ
Old 07-30-2013, 06:16 AM
Burning2nd's Avatar
Burning2nd Burning2nd is online now
Under the lift arms
Oh god ... Now we're welding ?????
Please please don't get me started
Lol
Tig= gas tungsten arc welding . A non consumable process (a different beast)
Stick= shelded metal arc welding ( farm welding)
Mig= gas metal arc welding ( most common for production and want to be welders)
My recommendation : just because u can stick two peices of metal together doesn't make u a welder
Seek professional class Time
Don't go welding suspension parts together until ur 100% sure in what ur doing
15486372<-----
Burning2nd's Avatar
Under the lift arms
Gtaw
Smaw
Gmaw
Fcaw
Best welding school o the east coast
Wtti
Welder training and testin institute in Bethlehem pa
15486372<-----
Old 07-30-2013, 07:07 AM
cj.surr's Avatar
some kid
Re: S52, now with more snail
Doh, this was an easier fix than I thought. All I needed to do was keep the 96+ strut hat and swap the non-m mount on
Also, I called that tech school in Bristol, but I would have to wait until school was in session in the fall.
Sent from my SCH-I405
-CJ
Old 07-30-2013, 08:59 AM
ZeGerman's Avatar
Warm Leatherette
Yes, it comes down to the FCABs. I first ran offset FCABs on non-M strut mounts & control arms. My wheels were a little bit forward in the wheel well, but not by much - no rubbing at all. When I upgraded my suspension, I switched to '95 M3 upper strut mounts, which then put the wheels exactly where they need to be when used in conjunction with the offset FCABs. If you were to use '96-99 upper strut mounts, you would want centered FCABs, and I believe you would have no trouble using stock non-M control arms.
If you use centered non-M upper strut mounts with centered FCABs and non-M control arms, your geometry will be fine - the same as all non-M cars. You just won't have the extra caster that M-cars do, which isn't a big deal.
1998 BMW 328is
1966 Pontiac GTO
Old 07-30-2013, 09:30 AM
cj.surr's Avatar
some kid
This is not true. That's what I tried, and the balljoint sits very far behind the spindle. That's why the 96+ M3's have different (longer) control arms.
You're right about the rest. I'm not really concerned about the lack of caster. I'd rather have quicker turn-in than high speed stability.
-CJ
Old 07-30-2013, 07:19 PM
BMRfanatic's Avatar
Wait what did you end up getting for suspension?
Ps, you were right about those radiator caps. My sister bought some weird rad but it fit
-Dino
Old 07-30-2013, 08:09 PM
cj.surr's Avatar
some kid
M3 konis with h&r sport. Trying to swap the springs for Race ones.
-CJ
Old 07-30-2013, 09:20 PM
Shigeta's Avatar
Shigeta Shigeta is offline
Old Soul
Mein Auto: '96 328is
Is there any way to not have Burning2nd's posts show up. Ever?
Old 07-30-2013, 09:28 PM
cj.surr's Avatar
some kid
Yeah I was thinking about that...
-CJ
Old 07-30-2013, 10:50 PM
Shigeta's Avatar
Old Soul
Killer! Thanks!
Old 07-31-2013, 02:29 AM
Burning2nd's Avatar
Under the lift arms
lol cant even handle being told the truth
15486372<-----
Old 07-31-2013, 06:15 AM
RockyTop316 RockyTop316 is offline
I bleed Orange.
Mein Auto: 1996 316i
People tend to take "the truth" a lot better when you're not a complete Deutschbag about it.
Originally Posted by another forum
John Moses Browning isn't God, but when God needs a firearm, he's the go-to guy.
ROCKY TOP, you'll always be...home sweet home to me....Good ol' Rocky Top, Rocky Top Tennessee!!!
Old 07-31-2013, 06:32 AM
Burning2nd's Avatar
Under the lift arms
Ok ... You tend to be talked at little bit more respectfully when your nose isn't pointed at the sky
Keep in mind that other people are on the road as well
So if you choose to be a back yard weekend warrior do that **** somewhere else where people don't have there kids In the car
I just can't get it how this particular section of the fourm is full of dh's grammar nazis and stuck up a holes
It's a fking e36 not a race car
15486372<-----
Old 07-31-2013, 06:36 AM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i / 99 540iA
Awesome! Now I just see "this message is hidden because Burning2nd is on your ignore list"
/day made.
Patrick ///04 330i ZHP///BMWCCA#465139
99 540i TiAg
98 328i hellrot (sold)
96 318iC black (sold)
Old 07-31-2013, 07:04 AM
Burning2nd's Avatar
Under the lift arms
nice add another to the denied list
15486372<-----
