The X5 SAV Forum
Old 07-07-2013, 08:56 AM
1200gs 1200gs is offline
Mein Auto: X5
Question Oil pressure warning
Took my x5 to car wash yesterday. Afterwards the low oil pressure warning was on.
Went off came back on. Etc.
Advice
Old 07-16-2013, 11:51 AM
sgtmario sgtmario is offline
Mein Auto: bmw x5
Hello, had the same with my x5, changed the fan clutch....no more problems......
Old 07-16-2013, 02:43 PM
tmvE39/E53/Z32's Avatar
tmvE39/E53/Z32 tmvE39/E53/Z32 is offline
Mein Auto: Dinan //M5, Dinan 4.8iS,
Advice
This would confuse me to no end. How the heck did you fix the "Low oil pressure warning" with a fan clutch? Must be a coincidence.
1200gs, I hope you didn't replace the fan clutch in hope of fixing the low oil pressure warning.
2000 Dinan S1 //M5 (my DD), 06 DINAN E53 4.8iS (wife's DD), 90 Straman Z32TT (my pride & joy ride)
Gone, but not forgotten: 01 E53 3.0i, 01 525i Sport, 03 DINAN 540i MSport, 01 //M5 and 91 Z32TT
Old 07-16-2013, 07:26 PM
Mein Auto: bmw x5
ok...sorry about that, let me explain...red oil light started to flicker with a/c on....
after reading all the posts and what people did.....somewhere i ended up on a post for fan clutch....i checked it out using a piece of a rubber hose.....fan stopped.....car started to overheat.....
so...i got a fan clutch and changed it...20 minutes......76$ at local part shop....
the X5 sounds like there s a jet engine inside now......no more oil light flickeing and no more message check oil pressure.......this only happened in hot weather and ac on.....
hope that helps you
Old 07-17-2013, 04:04 PM
upallnight upallnight is offline
Mein Auto: BMW, Lotus, Porsche
First thing I would have done was check the level of the oil, but that just me.
Old 07-17-2013, 06:33 PM
Mein Auto: bmw x5
oil level was checked....oil was fine......
Old 07-23-2013, 07:39 PM
puddinboo puddinboo is offline
Mein Auto: 2003 BMW X5
I would check to see if the oil filter is clogged up if the oil hasn`t been changed for a long time . ( a clogged oil filter will give you low oil pressure).
Old 07-25-2013, 06:14 AM
rwink181 rwink181 is offline
Mein Auto: X5
How do you replace the fan clutch? 20 min sounds to good to be true. I need to replace mine and i would prefer not to go to the dealer.
