Old 07-07-2013, 11:15 AM
pelaez335i pelaez335i is offline
pelaez335i
Mein Auto: 335i
Exclamation 2008 335i leak need help Asap
need help can some one please give me some advice on what this minor leak is ?
ID:	385489   Click image for larger version
Old 07-07-2013, 11:42 AM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
It appears your oil filter housing lid is weeping a little - either needs a new o-ring (which comes with the filter) or the lid has been over tightened and needs replaced which is pretty cheap also.
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
Old 07-07-2013, 12:27 PM
pelaez335i
Mein Auto: 335i
Thank you bro im going to look up on it ! Idk why my service light tells me -1400
Old 07-07-2013, 04:59 PM
The leak and your service indicator are not related, the service saying -1400 may be that it was not properly reset last service, so it now thinks it is overdue. If you recently have had it serviced, take off the oil filter lid, it just unscrewed counter clockwise - they make a special wrench, but a strap wrench will do the trick. Make sure the big O-Ring on the cap is not cut or damaged, inspect the lid for cracks and if all looks good, just put a little oil on the O-ring and screw back on by hand until the 2 arrows (one on the lid, one on the housing) align. Clean off all the old residue and if it comes back, you probably need a new lid.
Old 07-07-2013, 07:11 PM
harooni harooni is offline
2008 335i coupe
Mein Auto: 335i
one time a shop forgot to insert the oring on my old sel. same type of leak happened, make sure there is a oring around that filter housing.
2008 335i coupe sports package 2008 ML350
Old 07-07-2013, 09:07 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
[click here]
====> Shazam!
Old 07-08-2013, 07:57 AM
Mein Auto: '06 AW 330xi
Originally Posted by CALWATERBOY View Post
[click here]
====> Shazam!
This is a different leak. It looks like the OP's oil cap is leaking, not the housing gasket.
Old 07-08-2013, 01:10 PM
tmaster1 tmaster1 is offline
Mein Auto: e90 328i 2008,E93 335I 07
This Happen to me and it was that there was two O-Rings install the older one and the new one. So it was leaking in the same way. Take the cover out and inspected and the repair would be simple. You can reset the service warning by going to youtube, there is various videos that show how to do it.
335, bmw, leak, oil
