Old 07-07-2013, 12:06 PM
First740il First740il is offline
Mein Auto: 740il
Fans
Any one ever take off the clutch fan and put on electric fans?? Also would there be a horse power gain?? I would hope so!!
Old 07-14-2013, 06:32 PM
Podmore Podmore is offline
Mein Auto: 2001 BMW 735i
Any horsepower gain will be insignificant, as the viscous clutch allows the fan to freewheel at higher engine speeds thus minimising any power drain. You would need two thermatic fans to do the same job as the engine driven fan and the hassles of fitting two fans to an aluminium radiator in that crowded space, wiring, thermostatic switches etc outweigh any conceivable benefit IMHO.
Old 07-14-2013, 08:36 PM
Mein Auto: 740il
Re: Fans
There is more then enough space to fit fans, especially once the old fan is gone . I can hard wire them and just run a switch. Like old school... no??? I've had nothing but problems with it I just want that clutch fan gone.
Old 07-14-2013, 08:45 PM
Most problems with the fan clutch can be solved by replacing it ... what do you mean by "nothing but problems"?
Old 07-15-2013, 07:44 AM
JasonSC540ia JasonSC540ia is offline
Mein Auto: 1999 740i
To answer your question, yes. People have ditched the machanical fan for an elec one. Very easy and you dont have to worry about the mechanical fan ever coming apart. You can get an entire set up with temp control from jegs.com for about $150. Gives you 1-2 MPG better city driving, where the mechanical fan would be engaged.
HTML code is Off
