Old 07-07-2013, 04:28 PM
krishna112 krishna112 is offline
Mein Auto: 325i
Locked doors on BMW 325i cannot get in
I have a 2006 BMW 325i and the driver door is locked as well as the 2 back doors. I tried opening manually from inside as well as using the central lock / unlock button inside the car; i hear a small click whenever i click the FOB / central lock button but nothing happens.
What could have happened? What do I do?
Old 07-07-2013, 05:04 PM
tturedraider's Avatar
Freedom isn't free!!
You have a failed door lock actuator. It's possible more than one has failed, but it only takes one to cause havoc with the operation of all of them. This has probably caused the associated fuse to fail. At the moment I can't recall which fuse it is, but if you search "actuator" you should be able to find a post with the number pretty quickly. Or someone will probably post the fuse number here fairly soon.
www.bmwcca.org
