Old 07-07-2013, 06:58 PM
jlittle67 jlittle67 is offline
Mein Auto: 2012 328i Sport
2008 328i tire wear
The front drivers side tire is wearing on the inside pretty bad, the passenger tire seems to be ok, I had the same problem with the drivers side rear tire back in November and had both rear tires replaced along with a four wheel alignment. Could I get away with only replacing the drivers side front or do I need to replace both. I would suspect that since I'm going to replace it with non run flats I would need to both correct?
