Old 07-07-2013, 11:15 PM
glesther10 glesther10 is offline
Mein Auto: 760li
sound system
2006 760li....I really can't believe the stereo in this car is acting up ...I don't drive the car much .....68,000 miles I do not red line the volume... but there is a faint popping sound in the front passenger side door speaker ....has anyone else experienced this... is there an adjustment feature anywhere in the system.....or is a $600.00 speaker replacement the only solution...
Old 07-07-2013, 11:20 PM
chrisrees chrisrees is offline
Mein Auto: 02 745li
sound system
Logic 7 amp may need a replacement
Repairs 2012
wishbone & steering rack
Rfmd hydro steering gea
combination nu
Ball Joint
Tension strut with hydr
Switch unit steering column
Coils 5&7 and new spark plugs
Faulty DSC Control Module
Fuel Gauge
Leaking Crank Case Vent Valves
Power Steering pump, washer pump and grommont,
Crank Shaft position sensor
Total $13,481.37 in one year my mechanic swears all these parts are re engineered to work better than the originals lol
Old 07-07-2013, 11:41 PM
MoJo1978 MoJo1978 is offline
Mein Auto: 2007 750li
Re: sound system
Yup, I agree. Gotta b either ur amp or ASK unit. U may mistake ur door speaker popping 4 ur sub unda da seat. Jus take a closer look 2 b certain
Old 07-09-2013, 02:17 PM
Mein Auto: 760li
Thanx chrisrees.....I'll start from there...
Old 07-09-2013, 02:47 PM
dannyb1027's Avatar
dannyb1027 dannyb1027 is offline
Mein Auto: 2008 528xi
Get a fiber optic loop and bypass the L7 if the popping goes away then you've found the problem, If not bypass the next unit until you've isolated the faulty unit. you can't bypass the ASK unit so if all else shows to be ok then it's your ASK
Old 07-09-2013, 04:29 PM
PAPER's Avatar
PAPER PAPER is offline
CRISP & CLEAN
Mein Auto: Ford Pinto
May I suggest next time to perform a search .
There are plenty of topics on this subject with
the correct answer & steps to take to single
out the Faulty unit .
THANK YOU ...
