Old 07-08-2013, 11:21 AM
aalmans aalmans is offline
Mein Auto: 2003 BMW 745i
Car does not store Logic7 settings?
Guys,
I am hoping you can help me with something. Whenever i change my settings on my Logic 7 set like fader, balance, speed volume etc it forgets these settings when i turn off my car. This is getting really annoying.
Would someone know why this is? Am i doing something wrong? Do i need to actively store these settings somewhere or should the system remember the last setting?
Old 07-08-2013, 12:07 PM
Thesatman Thesatman is offline
Mein Auto: 2008 750LI
I'm guessing at this, but perhaps there is something that can be coded. I would think PAPER may know.
Sport Package, Rear Entertainment Package, Comfort Access, Cold Weather Package, Smoking Package, L7 High Def Audio
Mods = Powdercoated 149s, Black hood vent and kidneys, LED lighting update, BMW puddle lights (all doors), custom coding by "Triple_O_Coding" (including VIM), updated navi DVD from "PAPER", 90C hybrid thermostat.
Old 07-08-2013, 12:41 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
all the settings for the car are linked to the indivdual keys. Make sure that you are using the same key to adjust it! Also your key may need to be relinked to the car to work (comfort access, etc) with the settings. Does it remember your radio presets?
2013 TL Advance 3.5L
2006 BMW 760Li - Alpine White/Ebony-Ivory Two Tone
2010 Honda Accord EX - Basque Red/Ivory
lOE Fog Lightsl
2007 MDX Sport/Ent.- NGM/Taupe
lRB Slotted RotorslRoof RailslFront & Rear GarnishlAuto Mirrorl
2004 TL NAVI Auto - SSM/Quartz
lComptech SwaybarlHacked NavlTVNAV2GolUSA-SPEClDVD PlayerlSwitchblade KeylRB Slotted RotorslA-Spec Brakesl
Old 07-08-2013, 01:03 PM
Thanks guys,
I am the only one using the car and am using only one key. What can i do to test if this is key related? Do i need to code my key?
Old 07-08-2013, 01:25 PM
PAPER's Avatar
PAPER PAPER is offline
CRISP & CLEAN
Mein Auto: Ford Pinto
If you have never had this problem before then it could be
1 of 2 things =
if you have a comfort access key it could be the battery , if not
it may be your cars battery .
Old 07-08-2013, 01:45 PM
I just bought the car. No comfort access.
When i use either one of the keys i got with the car it does not change any settings (mirror, seat, radio presets) or anything.
Do these keys need to be enabled or something to actually store settings?
Are the keys somehow related to the "1" and "2" memory setting on the center console?
Confused...
Old 07-08-2013, 01:54 PM
PAPER's Avatar
CRISP & CLEAN
Confused...
yes your keys are connected to the car memory .
I would suggest that set everything in the car to
your satisfaction . Then push the M for 2 seconds
& then hit 1 or 2 to store it in .
be sure to set your seat , steering wheel , mirrors , radio ,
A/C settings , & anything else in the car .
Old 07-11-2013, 06:18 AM
Hi Paper,
Thanks for the suggestion. I did as you say and made sure i had different settings for chair, mirrors, steering wheel, temperature and radio presets when i stored this in Memory 2.
Selecting "1" again reverts chair, mirrors and steering settings wheel but NOT temperature and radio presents. the latter two stay the same and selecting "1" or "2" do not make them change at all?
Old 07-11-2013, 08:35 AM
I am almost positive there is a setting that needs to be coded or your key itself has issues.
Old 07-11-2013, 11:00 AM
I am not even using the key. Just pressing the "1" and "2" buttons on the center console drivers side...
Old 07-11-2013, 02:12 PM
PAPER's Avatar
CRISP & CLEAN
i am not even using the key. Just pressing the "1" and "2" buttons on the center console drivers side...
you should have the key in the slot & maybe even the car running
when your doing the 1 - 2 m button save
Old 07-12-2013, 07:32 AM
Your key fob stores all kinds of data: VIN, car info such as color, warranty information, and fault codes. It also saves your language preferences, audio, seat & climate settings. These individual settings can be programmed for I think up to 6 keys. And to be more accurate...the car stores some settings that are linked to what key is being used. Like I said before...if no configurations are being "stored/linked" to your key then I am pretty sure there is something wrong with the key OR the key is not identified and setup with a config.
Old 07-12-2013, 09:18 AM
Tried that as well. No difference.
It remembers the last settings as it seems when i park the car but it does not store settings in car memory "1" or "2"...??
Old 07-12-2013, 09:19 AM
How would i go about determining or fixing this? I have an ODB2 cable and can run software to code. Just not sure which program to use and how to do it...
Old 07-12-2013, 09:37 AM
fdriller9 fdriller9 is online now
Mein Auto: '06 AW 330xi
Have you previously coded your car before? There may be a value for key memory. Maybe in CAS? Not sure if E65 has CAS off the top of my head.
Old 07-17-2013, 10:09 AM
I have not coded my car before. I'll have a look myself. I believe there is a CAS module indeed...
