Gear changes - Bimmerfest - BMW Forums
Old 07-08-2013, 11:37 AM
Thrills Thrills is offline
Mein Auto: 95 BMW 740i
Gear changes
My 95 e38 gets stuck in third gear and I have to toggle the A/M switch when the rpm's are under 2.5. Is my tranny about to go or is this a treatable problem? It happens intermittely. (sp) Just wanted to get your advice.
Old 07-08-2013, 08:11 PM
First740il First740il is offline
Mein Auto: 740il
Re: Gear changes
What do you mean gets stuck??
Old 07-09-2013, 12:09 PM
It's like it doesn't want to shift.
Old 07-14-2013, 06:13 PM
Podmore Podmore is offline
Mein Auto: 2001 BMW 735i
More info required - "it's like it doesn't want to shift" is somewhat lacking in detail:
Do you mean the trans will not upshift or downshift at all unless shifted manually?
Or does the trans refuse to upshift unless the rpms are over 2500?
Does it downshift to 3rd when revs fall below 2500?
Under what road / load / heat conditions does this symptom occur?
Intermittently while driving on the same trip, or intermittently from one day to the next?
HTML code is Off
