Old 07-08-2013, 12:24 PM
Mk23's Avatar
Mk23 Mk23 is offline
Corner Carving Addict
Mein Auto: 09 - 335i E92
Removing sunroof to replace trim/felt. Any help?
Anyone know much about removing the sunroof? Looking to replace my badly faded trim around the exterior of the sunroof glass. Was told I would have to remove the sunroof to replace it. Dealership wanted $350 for it to be replaced when the trim piece itself costs $78. Figured I might could do it myself if I could find some info or a DIY on it. Any help?
Old 07-08-2013, 12:34 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
I'm about to do the same, and I'm going to use this DIY and see how it goes:
http://www.e90post.com/forums/showthread.php?t=594387
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 07-08-2013, 01:30 PM
Mein Auto: '06 AW 330xi
I've removed sunroof glass before. I need to, to wrap headliners.
First, take note of how the glass sits on in the roof. Remember how far up/low the glass sits in the roof.
Then, tilt the sunroof up, remove the rubber trim pieces on either side of the sunroof. They look like accordions lol. Then you'll have access to 6 torx screws, 3 on either side. I believe they are T25 torx screws, not 100% on that. Try to mark the screw locations with a white out pen or something.
After removing the screws, you can lift the glass out. Don't move the motor or anything once it's out.
To reinstall, just go in the reverse order above. You'll need to play with the screws and placement for a bit to get it back to where it was or else it will not seal.
Old 07-09-2013, 12:18 PM
Mk23's Avatar
Thanks you two! Will have to go ahead and order that gasket. Quick question, is there a way to order the special tools needed to do this job or are there other alternatives to them? I want to make sure and line everything up perfectly as it looks like you have to judge a couple of things distance from other parts.
Old 07-09-2013, 12:28 PM
No problem. You just need torx bits. I think they are T25 but not 100%
Old 09-20-2013, 12:35 PM
Mk23's Avatar
Just wanted to update this and say that the sunroof came out very easy. Just remove the two accordion looking rubber pieces on both sides (after tilting the sunroof open), then remove the two torx screws on each side. the sunroof slides out very easy after that. didn't even take me 5 mins to take out the sunroof and I had never done it before.
After the sunroof was out I pulled off the old gasket/felt trim and to my relief there was no sealant on the inside and was just held in by the rubber. Though I did have to cut mine as I had a decent amount of slack after it was fitted in all around (and FYI it is a pain to get the gasket pressed in hard enough to stay in all the way around). I cut the gasket down a bit and used a sealant to paste the two end together. was a bit tricky on that part but it turned out well.
Hopefully these three links will help out anyone wanting to attempt this:
http://forums.5series.net/diy-do-you...nt-diy-132606/
http://www.realoem.com/bmw/showparts...41&hg=54&fg=05
