Old 07-09-2013, 08:18 AM
MyX1 MyX1 is offline
Mein Auto: X1
NAV Day/Night mode?
Does anyone know if there is an option to have the NAV map automatically switch between day and night mode?
For example when the lights come on have the map switch to night mode, when the lights are off, switch back to regular display?
Old 07-09-2013, 10:01 PM
3drockz 3drockz is offline
Mein Auto: BMW X1 x128
I havent found an option like that... and im really not sure why BMW didnt have the common sense to switch to night mode when it gets dark!! Even a $100 garmin does it
Old 07-10-2013, 04:22 AM
nospam nospam is offline
Mein Auto: X1 x28i; 128i; S2000
F Series vehicles have this option, E Series do not.
Old 07-10-2013, 06:17 AM
the_fox's Avatar
the_fox the_fox is offline
Custom User
Mein Auto: 428GC
You can program a memory button to do that for you.
Do not fold, staple, or mutilate. Void where prohibited.
Old 07-10-2013, 07:53 AM
nbercasio nbercasio is offline
Mein Auto: BMW 535i and BMW X1
why create two threads?
Old 07-10-2013, 08:48 AM
whitby whitby is offline
Mein Auto: BMW
I have always assumed that the lack of such a function in the X1 is because they are deliberately creating model differentiation (like no air vents in the back, although that is probably cost saving as real hardware is involved, the lack of day/night mode has got to be just software hence my irritation). After all the X1 is the cheapest BMW in the US portfolio.
Cheers,
2015 Glacier Silver 428i Gran Coupe
2015 British Racing Green Mini Cooper S 4 Door Hardtop
2012 Space Grey 528i MSport - retired
2013 Valencia Orange X1 xDrive 28i Msport - retired
Old 07-10-2013, 09:24 AM
Mein Auto: X1
Sorry, for some reason I can't find the delete button when I try to edit the thread - where is it???
Old 07-11-2013, 07:40 PM
edman edman is offline
Mein Auto: 2014 X1 xDrive 28i
Re: NAV Day/Night mode?
I never thought about that. Great idea. I'll have to try it and I have one memory button left.
Old 08-09-2013, 10:34 AM
skr9 skr9 is offline
Mein Auto: X1 xDrive 35i
What "memory button" are you using to switch from day/night?
Old 08-09-2013, 10:35 AM
switch from day/night? They turn on when the headlights are turned on (and i have auto headlights so when it gets dark, the interior ambients turn on)
Old 08-09-2013, 10:40 AM
Kzang Kzang is offline
Mein Auto: 2015 X5 ///Msport 35i
Just below your air temperature control area there should be 8 buttons. You can use those buttons as a quick shortcut button.. You can program one of those buttons to switch your nav from day/night view.
Read your owners manual for how to program these buttons.
2015 X5 Msport Space Grey
Old 08-09-2013, 10:46 AM
spydrz's Avatar
spydrz spydrz is offline
Sandlapper Chapter
Mein Auto: 2013 X1 xDrive35i
*Rushes outside to program this*
Great idea!
1984 318i/man./Tornadorot*
1990 525i/man./Alpinweiß*
2001 525i/man./SP/PP/Cosmosschwarz/Sandbeige*
2002 X5 3.0i/man./SP/PP/Sirius/BT/Titansilber/Sandbeige*
2006 330i/man./SP/PP/CWP/Sirius/Blackline/Rear Fogs/Arktis/Grau*
2001 525i/step./SP/PP/CP/CWP/Xenons/Rear Shade/OEM Sirius/OEM BT/OEM AUX/M5 Rear Sway/Bilstein HDs/Beisan Vanos/Rear Fogs/Schiefergrün/Sandbeige*
2012 VW Golf R/Rising Blue*
2013 X1 xDrive35i Alpinweiß/Schwarz/M Sport/Premium/Tech/Dinan Stage 2
*retired
Old 08-09-2013, 10:51 AM
Yea, im aware of the memory buttons and use them for contacts and music... where in iDrive is the setting for day/night view?
Old 08-09-2013, 11:49 AM
in Nav screen, click option on idrive controls > display settings > and it should have night view.
At least this is how it is on my X5.
Old 08-09-2013, 12:05 PM
Mein Auto: X1
Actually, the X1 only has 6 buttons (not 8)
Old 08-09-2013, 12:58 PM
DCC DCC is offline
BMW Fan
Mein Auto: '02 Z3 M Coupe
Do you have to have the Nav screen already in night mode before you assign the button? Mine is not doing the switch after I set the button to toggle it between Day/Night mode
2016 320i Sedan
2011 M3 Sedan
2002 Z3M Coupe
Old 08-09-2013, 01:21 PM
Mein Auto: X1
It shouldn't matter what mode it's in. Just go to the menu where you toggle the mode, and then hit one of the memory keys and hold it.
Old 08-09-2013, 03:21 PM
KaKiT KaKiT is offline
Mein Auto: 2014 BMW X1 XLine
Press right via iDrive and you will get the "option" button. Via this menu u can change the day/night mode. You also add this to a shortcut.
