Old 07-09-2013, 09:58 PM
nguyennhatquang nguyennhatquang is offline
Mein Auto: 750li e65
BMW E65 750li 2006 LM1 to LM2 question
Hello you guy.
After spending lot of time for research. i found out..
FROM LCI car..u doesn't need to swap pin like people said. It bull****..
if u look at the wiring diagram. PIN 17 not use. PIN 60 is the led light to the light switch...even if u doesn't swap it still work ok. Just lost the light.
here is the pic i did it. I did it with ISTA P and NCSexpert.
from PRE LCI car, it have AHL module. Old LM module doesn't have AHL build inside it. SO u need to WIRE it again. or all of your i Level will ** up. Take old AHL out. LM2 have build in AHL inside it.
U can check a proper install by ISTA P recognize it or not. IF it not recognize well mean your installation have a problem. Vertical light AHL can't go up and dow... xxxx
video Welcome light...
[video=youtube;W_6qSKkw0Bc]
Old 07-09-2013, 10:21 PM
PAPER's Avatar
PAPER PAPER is online now
CRISP & CLEAN
Mein Auto: Ford Pinto
Originally Posted by nguyennhatquang View Post
Hello you guy.
i have a 750li E65 LCI. first time i was thought my LM was LM2 but actually it is LM1.
i found an instruction in here how to change LM1 to LM2 but the instruction only for E60 that why i wonder.
Are there anyway i can fit LM2 in my E65 750li so i can have DRL as angel eye and welcome light.
The instruction only for E60 that why i wonder.
Thank you so much.
you should only need to install & swap pin 17 - 60 .
then write VO & code to the features you want .
Old 07-09-2013, 11:11 PM
sorry my engine is bad..
what u mean is i swap the pin 17 and 60 in my LM1 module?
then after that enable DRL light via ISSS? (ISTA P)
i can't find the Welcome light in my 7..
Thank you
Old 01-08-2014, 07:05 PM
rippjd rippjd is offline
Mein Auto: '05 745i / '10 X5 35d
According to TIS you only need to swap 1 wire if your car was built 03/2003 or older and you are installing a newer LMA module.
Name:	Pin Swap for 03_2003 or older.jpg
2005 745i Individual
E65/E66 Parts for Sale:
Alpina Type 743 Front Spoiler complete retrofit kit (new in box) $1200
Old 01-08-2014, 08:02 PM
PAPER's Avatar
CRISP & CLEAN
why even bother bumping this old ass topic with the same answer
that was already given to the OP ???
Old 01-08-2014, 10:39 PM
mybmw408's Avatar
mybmw408 mybmw408 is offline
Mein Auto: BMW 750i
How do you know if you have LM1 or LM2???
what he said is not the same as u said.
He said if my car was build after 2004 then i do not need to swap the PIN.
my car is 2005 so..
@paper : u're talking about the VO i need to write. What is that VO number?
Regards
Old 01-08-2014, 10:43 PM
mybmw408's Avatar
Mein Auto: BMW 750i
My car was built 12/06
2007 750i sport
Old 01-08-2014, 10:47 PM
@mybmw408 : what u're trying to say?
u want to retrofit LM2 or your car already have LM2 module?
Regard.
Old 01-08-2014, 11:15 PM
mybmw408's Avatar
Mein Auto: BMW 750i
How do I know what module type is in my car???
Old 01-08-2014, 11:19 PM
PAPER's Avatar
CRISP & CLEAN
my car is 2005 so..
Regards
well I have installed an LM2 in an 05 & I still had to to swap PIN 17 & 60 , So his
dates don't actually mean anything . It all depends on the car itself .
With that said maybe you can ask him about the V.O.
I'm done helping out for the day ...
Old 01-09-2014, 12:05 AM
i don't think u need to piss off so much like that.
All in here is sharing and experience, and help each other guy.
If u know what is the VO no please tell us.
maybe he just pop up the Document and haven't install it either
Regards.
Old 01-09-2014, 06:29 AM
@mybmw.. I think u have same lm1 like mine. U can check by ncsexpert.
I already order lm2.. Just waiting for some one who willing to help about vo number
Old 01-14-2014, 06:46 PM
I used this as a guide:
http://www.bmwcoding.com/showthread....LM1-to-LM2-E60
Though I started with Step 8 to code the VIN, then went to update the VO (Vehicle Order) which is called "FA" in NCSExpert, and finally coded the LM2.
I just installed the LM2 and haven't played with any custom coding yet...
Old 01-14-2014, 07:06 PM
PAPER's Avatar
CRISP & CLEAN
Originally Posted by mrbmwx5 View Post
you're a mod of this site and please don't be a dick to everyone . ****ing jerk.
Go ahead and bann me please ...
ok I'll be happy to do as you ask ....
Old 01-14-2014, 07:36 PM
dvanlare dvanlare is offline
Mein Auto: '95 E31, '05 E66, '15 F02
LM2 Upgrade
I am trying to upgrade my LM1 to LM2. I bought what I thought was the correct module on eBay labeled as LM2 LWR type but instead it came as an AHL version. I have a 2005 E66 with self leveling xenon which is not the same as the newer adaptive headlight so I think it isn't compatible. Before I search for the correct one I was wondering if anyone knows if it can be coded properly for non AHL. Part is 61359137776 and I think I need 61359153272, 61359154943, 61359180756, 61359192641, or 61359203081. Anyway, I connected it, wrote the VO, changed the VIN, defaulted it to my VO but the side marker lights don't work and I am getting several errors on INPA that I can't clear.
Old 01-14-2014, 08:45 PM
@rippjd : is ISTA P recognize your LM2 module?
that is the most i'm concern.
i did LM2 in E60 then when i use ISTA P it said replace LM2 and all the module.
Old 01-16-2014, 05:03 PM
If you don't have adaptive headlights "AHL" (SA524 = No), I would think your module which supports AHL just would have that option turned off. You just wouldn't use that hardware portion of the LM2. I do see ETK has a different part list for the non-AHL LM2, as you've listed above.
I have AHL and picked up a used 61359203081 which shouldn't support AHL, but as I have a pre-facelift car my AHL and LWR are both controlled by a separate module behind the glove box. Note that this separate module is called the ALC.
Below are the settings I used. I haven't experimented to confirm all are necessary. Translations curtesy of NCSDummy.
With these settings the Welcome Lights include; Angel eyes, side position lights in 4 corners (North America only), rear LED taillights & license plate lights. They illuminate for about 20 seconds. You do need to have the headlight switch in the AUTO position for the Welcome Lights to work.
WELCOME_LIGHT_ACTIVE WELCOME LIGHTS IN LIGHTS MENU (LINKED TO [VA_WELCOMELIGHT] IN CAPPL)
aktiv enabled *
nicht_aktiv not enabled
WL_SL_1 WELCOME LIGHTS WITH STANDING LIGHTS 2
soft_einschalten soft-on *
hart_einschalten direct switch-on
WL_KZL WELCOME LIGHTS WITH LICENSE PLATE LIGHTS
DEF_WELCOMELIGHT_CKM DEFAULT CAR/KEY MEMORY FOR WELCOME LIGHTS
aktiv enabled *
WELCOMELIGHT_CKM_0 CAR/KEY MEMORY 1 FOR WELCOME LIGHTS
aktiv enabled *
Eventually I may post a summary in the DIY section...
Old 01-29-2014, 03:02 AM
LM2 installation is done.
Any one think it is helpful and need help let me know.
Old 01-29-2014, 04:39 AM
dannyb1027's Avatar
dannyb1027 dannyb1027 is offline
Mein Auto: 2008 528xi
Old 01-29-2014, 01:43 PM
mybmw408's Avatar
Mein Auto: BMW 750i
My car came with LM2, just seen it in DIS
Old 01-31-2014, 07:42 PM
U can read it with ncs expert then code it like mine.
it will be cool
Old 01-31-2014, 08:12 PM
mybmw408's Avatar
Mein Auto: BMW 750i
it will be cool
I already have lights come on when I hit the panic button inside and out, same as yours. It was like that since I bought it.
Old 02-04-2014, 08:14 AM
all bmw 7 come with this light when u hit the panic button even with LM1
with LM2
u can code
cornering light as fog light..it will auto turn on when the steering is turn
wellcome light
if u hit open or pull up the door handle ..the light will come up without hit the panic button like mine.
most important
angel eyes as DRL light...it will look so cool like new model car those day,
Old 08-09-2014, 05:40 PM
B11NOV B11NOV is offline
Mein Auto: E65 730D
with LM2
u can code
wellcome light
most important
Hi nguyenhatquang, sorry to bump up an old thread, but have you managed to get the cornering light and DRL with angel eyes? I just installed a LM2 to my 2005 E65, managed to get welcome light working, but not the other two. Would you be possible to send me your trace file so that I can see what's missing? Thank you very much.
