Old 07-10-2013, 06:43 AM
steenport567 steenport567 is offline
Mein Auto: 2005 X3 2.5i
X3 starts rough
All,
My '05 X3, just after ignition, was a little rough. I thought it was bad gas but the engine light came on.
Time to replace some fuel injectors or just run some cleaner through it?
Old 07-10-2013, 07:24 AM
Burning2nd's Avatar
Under the lift arms
Before you start replacing stuff or even assuming you know what needs to be fixed why don't you confirm what's wrong ?
15486372<-----
Old 07-10-2013, 07:57 AM
X3 starts rough
Yes, this was my next step.
Old 07-10-2013, 09:30 AM
joylove joylove is offline
Mein Auto: 08 e83 LCI
Fault code reader.
Lumpy idle when cold often comes back to perished hoses for the PCV. To access them requires removal of the intake manifold. It is recommended to consider replacing the starter motor at the same time as they can go at 80-100k miles.
Old 07-10-2013, 11:15 AM
X3 starts rough
Interesting. Just had the PCV and hoses replaced last year. That problem also comes with black smoke out the tail pipe.
Ill have the code scanned.
Old 07-11-2013, 11:18 AM
X3 starts rough
Had the codes scanned yesterday. Bad gas possibly. Will try the injector cleaner. If this doesn't work I will clean the injectors myself .
Old 07-22-2013, 11:01 AM
X3 starts rough
I went to O'reilys and had them scan the car. Several codes can back and it was determined that 4 of the cylinders where not working properly due to possible bad spark plugs. Will install today.
