E34 (1989 - 1995)
Old 07-10-2013, 10:22 AM
vbrotz62 vbrotz62 is offline
Mein Auto: bmw525i
service tools
I have a 1990 bmw 525i 5 speed manual.I have a snap on versus diagnostic computer which I updated for imports,but it only goes back to 1992,and will not read my car.Will an ecu from a 1994 530i make this thing work?I have one I could try?I read they are compatible from 1989 to 1995.
Old 07-10-2013, 10:28 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
No. The ECU's are not compatable. I'm not sure what kind of data you are after, but you may be able to use this procedure to pull any error codes that are stored in your current ECU.
I say "may be" only because the Bentley manual indicates that it only works for 92 and up, but many others here with cars older than 92 have been able to do it.
Hope this helps.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 07-10-2013, 11:07 AM
Mein Auto: bmw525i
I know the stomp test,but I'm having multiple electrical issues,cruise control,backround illumination on cluster,but all signal lights ect work.no button lights on trip computer,windows,low beams and sunroof work sporatically.a/c the same works sometimes.I'm thinking a bad ground or a bare wire somewhere. l
Old 07-14-2013, 11:02 AM
Mein Auto: 1989 525i M20B25
All of those small things can be fixed with a DVOM, bulbs, and some cleaning tools.
Pulling codes on our cars will not give information about things other than the engine. Is that what you are trying to find out?
What's wrong with the stomp test? If it is not working you may need to adjust the TPS.
Old 07-14-2013, 12:05 PM
bigugly fab bigugly fab is offline
Dr.BMW
Mein Auto: 2015 M4
That snap on scanner isn't going to help you.
you need to chase wiring issues like that the manual way, with a book and a DVOM.
sorry, but domestic scanners don't work well for BMW's.
