Old 07-10-2013, 07:53 PM
lqaddict's Avatar
lqaddict lqaddict is offline
Salz und Pfeffer
Mein Auto: 2014 F22 M235i
BMW gremlins
Well it happened.
Started up the car passenger airbag off warning stayed on and the seatbelt warning lit up and won't go away. I restarted the car but the same warnings remained. Strangely, there was no annoying dong for the seatbelt.
However, both disappeared after I left the car shut off for 5 minutes while getting coffee
BMW CCA Member 454031
Save the manuals
Old 07-11-2013, 06:43 AM
Mein Auto: '06 AW 330xi
Passenger seat mat sensor is a common failure on early build E90s. There was a service bulletin released and I believe a recall as well because in the event of an accident, if the seat mat sensor is faulty, the passenger air bag will deploy regardless if there is a passenger there or not. This is a safety hazard for a child that doesn't meet the 70 or 90lb weight requirement. (or whatever the requirement is).
Have the shadow fault codes pulled from the ABG module. See if there is a fault relating to OC3. If there is, you can ask your dealer if your VIN falls under the recall.
Old 07-11-2013, 07:29 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Another good reason to wait for the 3rd, preferably 4th year of production!
Old 07-11-2013, 07:42 AM
cwinter's Avatar
cwinter cwinter is offline
Here comes trouble!
Mein Auto: 2009 328i E90 :)
It ain't a gremlin unless it comes back!
(Hope it doesn't though!) At least it seems to be a known issue, which is great for electrical gremlins, as often it is hard to figure where to even start troubleshooting! Wonder if this would store codes the mechanics could use to isolate the issue.
2009 328i Sedan - Ordered: 2/24/09 .:. Delivered: 5/6/09
Jet Black | Black Dakota | Aluminum | Premium | Sport | Xenon | CA | Split Fold Seats
You will rue this day, RUE THIS DAY
Old 07-11-2013, 07:59 AM
Yea but I love my 330! lol They only made them in late 05 and 06 for E90s in the US.
In Europe they still produce them, well not now since the F30 was released. But the euro version is direct injected and make a bit more power :/ Europe always gets the better version...
Old 07-11-2013, 08:22 AM
lqaddict's Avatar
Salz und Pfeffer
Hmm, mine is actually the last year production for the E90 chassis.
No open recalls or TSB's found.
Save the manuals
Old 07-11-2013, 08:31 AM
Well if the error doesn't pop up again, I wouldn't worry about it.
There is most likely a shadow fault in your ABG module though. So if you want to look further into the situation, have the module scanned and pull the shadow fault if there is one.
Old 07-11-2013, 08:44 AM
lqaddict's Avatar
Salz und Pfeffer
I will stop by my friends mechanics and see if they still have Bavarian Technic diagnostic tool.
Save the manuals
Old 07-11-2013, 08:19 PM
pointandgo's Avatar
Mein Auto: '13 F10 535i (loaner)
That was quite a while ago and covers:
http://www.bmwusa.com/Standard/Conte...aryRecall.aspx
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 07-12-2013, 09:38 PM
unrealii unrealii is offline
Mein Auto: 2009 335 6MT 'vert
Did you throw something on the passenger seat while starting the car? I was able to trip the warning on mine when I dropped my phone on the passenger seat while starting the car.
2009 335i 6MT M-Sport AW/CR Convertible
2002 Toyota 4Runner 4wd
