Navigation Problem - Bimmerfest - BMW Forums
Old 07-11-2013, 10:25 AM
NoCornersCut NoCornersCut is offline
Mein Auto: 2000 740iL
Exclamation Navigation Problem
Here's what's going on with the BMW. I recently removed the nav disc player from the trunk so I could get a better look at the factory amp. Well during the reinstall I thought it would be a good idea to remove the nav disc... now the player won't take the disc back in.... Is there a certain procedure to make the unit accept the disc? (vehicle must be running, etc.) Or is she broke??
-Matt
Old 07-14-2013, 05:58 PM
Podmore Podmore is offline
Mein Auto: 2001 BMW 735i
At what point did you actually remove the disc from the unit? You say 'during the reinstall' - did you have the battery disconnected during the removal process?
In order to remove the disc, you must have had power to the unit; I am assuming that the battery was connected (sorry if it's a statement of the blindingly obvious) when you tried to reinsert the disc.
The ignition key must be at Position I or II; you should see the Power light on the face of the nav player. If there is no power light with the key at I or II on then check to make sure you plugged everything back in properly. Check the fuse on the unit itself.
HTML code is Off
