Old 07-11-2013, 02:34 PM
snyds12 snyds12 is offline
Mein Auto: X5
2009 X5 fuse panel layout
looking for a picture -- need the liftgate fuse location. Also, panel folds down but underwires make it very difficult to access fuses, am i missing something?
Old 08-02-2013, 03:38 AM
jrnesci jrnesci is offline
Mein Auto: 2008 X5
http://www.bimmerfest.com/forums/att...8&d=1372018911
Not sure if this is what you're looking for. I have an 08 X5 and this is correct for mine, even though it's for a 2011. Let me know if it's not what you're looking for and I'll try to help you.
Old 08-02-2013, 04:53 AM
Mein Auto: 2008 X5
http://www.bimmerfest.com/forums/att...9&d=1372018911
This also goes with the diagram.
Old 08-07-2013, 08:36 AM
vruss7 vruss7 is offline
Mein Auto: BMW X-5
Can either of you direct me to the location of the fuse panel. I thought it was under the three screw panel below the steering wheel. My problem is that the front power plug( lighter) is not working the other three work fine. Tks
Old 08-08-2013, 02:25 PM
Mein Auto: BMW X-5
FYI and future reference. Fuse panel is located on the right(passenger side) behind removable panel. Lift the soundproofing flap and there it is and on the right side the diagram is in a slot. for the power plugs note the symbol on the cargo compartment power plug. Diagram points you to 4 numbered panel slots and also cross references the fuse amp. for [power outlets they are 97, 111, etc a red fuse puller is on the panel and easy to use. Found the 111 slot fuse blown and bought new ones at auto store nothing needed from BMW. They come five to a package for $4.76. Back in business and power plug works. Fingers crossed it does not blow again which would mean electrical problem.
Old 03-05-2014, 03:21 PM
stiremup stiremup is offline
Mein Auto: 07 x5
Hello everyone I am new so please forgive any ignorance
I have a 2007 e70 or x5 3.0 my airpump fuse or relay went out so
my car sags and bounces any clue where to find them?
thank for any help.
Stiremup
Old 03-06-2014, 06:44 AM
Mein Auto: 2008 X5
The fuse is located in the fuse box under the glove box, Fuse number 32. Use the diagram links in this thread for the exact physical location of the fuse.
Old 03-06-2014, 10:05 AM
Mein Auto: 07 x5
Smile thank You!
yesterday I probed in the fusebox in the back and somehow knocked my audio
out the cd player counts down just no sound so now I have 2 problems not just one.
Oh well!
Old 03-11-2015, 06:47 PM
howskitz howskitz is offline
Mein Auto: 2008 BMW X5 E70
fuse for nav display screen
Hello! Hoping someone can help me please! Our power (lighter) plugs weren't working in the car. Found the fuse box in the rear cargo area and located the power plug fuses 111, 113, 115 and 118. Swapped out blown one with one that worked from the Jap N icon one on the picture side. Front power plugged then worked. Realised the one we pulled out 137 has now done something to the nav screen as nothing comes up on the screen. We replaced fuse into 137 but still nothing happening. Any suggestions on what we can try? Any ideas on what fuse locations relate to the screen? Cheers!
Old 03-30-2015, 06:19 PM
nevillem nevillem is offline
Mein Auto: X5 E70
Fuse for Nav screen display
Howskitz - did you have any luck ? I have a similar problem with no back light on the screen although all functions still work. Thought it might be a fuse but don't know which one. Looked at fuse legend but its very confusing, not clear which is fuse for display screen.
Anyone else able to help ?
Old 01-01-2016, 07:44 PM
Holy Smokes Holy Smokes is offline
Mein Auto: 2008 X5
Old thread resurrected I know..... But having a similar problem. iDrive screen just went blank yesterday. Appears to be back light. Is this a fuse issue or a whole display issue?
Oh ya, just obtained this new-to-me 2008 X5 3.0i three days ago.
Old 01-01-2016, 10:15 PM
Mein Auto: X5 E70
Don't have any specific solution, but don't think its a fuse problem, just something quirky with the electronics of that model. From my experience it happens when outside temp is cold. Display comes good after a period of time, can be hours, days or weeks !!
One suggestion, after it comes good (hopefully), each time you go to start the car you first put the key into the slot (of course) but then you MUST WAIT until the display lights up before you push the start button. You could also try that before it has come good.
Btw I sold my E70, now have an F15 30D M sport, absolutely love it.
Old 01-02-2016, 04:46 AM
Mein Auto: 2008 X5
Ours is a different case then.
In Florida and ambient temp was in the 80's. This particular X5 has the proximity option so key was not in the slot when I pushed start. Screen just never lit up.
Old 01-02-2016, 07:56 AM
Mein Auto: 2008 X5
Ok, so I compare the diagram to my actual panel and see multiple fuses calling for a fuse but nothing is there. Sure it depends on what options are on it but would it hurt to fill those slots with the proper sized fuse regardless if it's a system on the vehicle or not? Plus I assume all the un-diagrammed slots with fuses in them are just spares.
Old 01-07-2016, 01:45 PM
Mein Auto: 2008 X5
UPDATE - Blank screen resurrected itself after being off for 3 days. Not sure what the hell it was, hopped in Tuesday morning and it came back to life!
I had tried several other remedies and had no positive results, i.e. pull & replace fuses, attempt to reset display, etc. I did, however, read today that I may not have been resetting the display correctly. Initially, I tried pushing the CD eject and volume buttons simultaneously for 25 seconds to no avail. Another poster mentioned that you have to hold down the CD eject, volume AND the NAV DVD eject button as well.
We'll see what the future holds!
Old 03-19-2016, 06:51 AM
Sidneyns Sidneyns is offline
Mein Auto: Bmw x5 e70 2008
Rain sensor fuse number please
Hi guys I have a 2008 x5 and my rain sensor is not working. Do you know the fuse location and number ?
Old 05-16-2016, 12:37 PM
2007BMWX53.0 2007BMWX53.0 is offline
Mein Auto: 2007 bmw x5 3.0
Nav screen is very dim
Hi. All of a sudden my nav. Screen went super dim. Thought it was battery issues but everything's working well. Read a lot here like the 2 eject button + press the volume to reset it and yes, It would restart but still be super dim after restarting. Haven't tried the cargo fuse thing yet, not sure which fuse.. Please advice! Thanks!
Old 05-16-2016, 12:42 PM
blue dragon blue dragon is offline
Mein Auto: X5 35D
The backlight on the LCD screen is going. You will need to replace the screen or be handy with electronics.
| '09 X5 35D - Work horse | '17 X1 MSport - Wife's daily | '17 - 340i MSport - My daily |
Old 05-16-2016, 12:50 PM
All of a sudden? At lunch it was well lit until i was about to go home when i started the engine, it never went on.. You need to point a light at it to see what's on the screen.. Need to replace the screen??? No other solution?
Old 05-16-2016, 12:58 PM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: 2012 Feb 11 X5 35d (E70)
Change the fluorescent backlight just as you may on your laptop. LCD's make no light of their own but are placed in front of a light source. It was a half hour job on my almost ten year old Dell. And yes, it fails suddenly and usually on start up.
I am responsible for what I write, not for your understanding of it.
Old 05-16-2016, 01:38 PM
I see. I'll try and get it checked.. Thanks for the infos.
Old 03-13-2017, 11:46 AM
rev hrd rev hrd is offline
Mein Auto: 530iA Sport
Can you guys help to find the fuse? I'm looking for the E70 X5 GWS module which is the electronic Gear Lever Shifter fuse. Since there is no light at all showing in Park on the shifter, I want to confirm if the fuse is ok before I order the entire module cost ~$1000.
My X5 engine starts without issue, but it doesn't go into gear since there is no light in Park.
Old 03-13-2017, 12:07 PM
Thirdy Thirdy is offline
Mein Auto: E70Diesel, E46
you can access fuse location with the fuse guide at the rear right side panel of the cargo area/trunk. The other fuse location is right under the the passenger kick panel area.
Remove 3 screws and remove under panel and unscrew green colored screw to lower the fuse holder.
Old 03-20-2017, 09:15 PM
migjet11 migjet11 is offline
Mein Auto: 05 X5, 06 325i
2008 E70 X5 headlight fuse number
I don't think I'm stoopid so why cant I figure out which fuse is associated with my passenger side headlight. That fuse box diagram is confusing. I replaced the bulb but it still doesn't work. I should've checked the fuse first.
Thanx
fuse box
