Old 07-12-2013, 02:22 AM
Mk23's Avatar
Mk23 Mk23 is offline
Corner Carving Addict
Mein Auto: 09 - 335i E92
New turbos need a break-in?
So I just got my turbos replaced under the extended warranty and I was wondering if there is a break-in period. Anyone know?
Old 07-12-2013, 04:56 AM
angler's Avatar
angler angler is offline
1 Converted Addict
Mein Auto: 135i M-Sport 6mt Cabrio
Ask dealer
PSS|PPK|PE|LUX H8 V4's|CDV Delete|
Old 07-12-2013, 07:15 AM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
There is no break-in.
Old 07-12-2013, 07:22 AM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E60, E71, E92
Nope, but Mike Miller, BMW CCA tech-editor says warm-up and cool-down is a must for turbo engine. I never shut down my engine right of the bat on hot summer days. @51K-miles, tuned and hard driving my N54 never (or hasn't) develops waste-gate rattle. Knock-knock on woods.
Old 07-12-2013, 11:19 AM
Mk23's Avatar
Originally Posted by angler View Post
Ask dealer
I asked, he said there should be, but he didn't know the process or for how long.
Can I ask where you heard that from? Just would rather be safe than sorry.
Oh I hear ya, I've been doing that for 4 years on this car. Usually keep it under 3k RPMS for the last 5-10 mins of the drive and vice versa when going out (also wait till temp is at least 240).
Old 07-12-2013, 11:58 AM
bear-avhistory's Avatar
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
Any new rotating assembly should be broken in, just don't flog it for a few hundred miles.
Kevin
CURRENT:
2018 BMW 440M-Sport MPPSK/MPE 8ZF
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
477 WHP of BURBBLES
HOME FROM PAINT
Old 07-12-2013, 12:25 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
This. Says as much in the owner's manual, too.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 07-12-2013, 02:43 PM
johnc_22's Avatar
johnc_22 johnc_22 is offline
Squeal like a BMW
Mein Auto: 2013 Audi A4
Any idea why your turbos failed?
2013 Audi A4 - Premium+/Sport/MMI/B+O Audio
2007 BMW E90 335i (retired)
Old 07-12-2013, 02:50 PM
Banned
Mein Auto: 2007-335 HTC
my opinion is evey day you warm them up before you wind them up
Old 07-13-2013, 12:06 AM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
I thought you were supposed to wait until your oil temp kicks off the left hash mark. This way you know it is ready to lubricate those spinners properly. I always wait and keep it under 3k rpm. The JB4 also has an indicator option for this so you know when you can step on it so I have that activated as well.
Old 07-13-2013, 12:29 AM
Mk23's Avatar
Thank you for the help! That's what I needed!
Wastegate was staying slightly open and was not holding boost. I was covered under the extended warranty BMW put out (thank Jesus), otherwise It would have been a $5k repair with labor and parts.
Old 07-13-2013, 05:27 AM
TXFred TXFred is offline
Mein Auto: 2008 335i Convertible
This is correct. The problem with a hot shutdown is that the turbo is hot, but the oil flow ceases. So the oil left on the turbo's shaft begins to cook, leaving behind carbon deposits.
The usual solution is to take it easy for the last two minutes of your drive, putting along or idling, before shutting down.
The better solution is an after-oiler, which will keep oil moving through the turbo after the engine has shut down. This continued oil flow will carry the heat away from the turbo's center section, cooling it an preventing carbon buildup.
Frederic
Any idiot can be fast in a straight line. The corners are what separates the drivers from the commuters.
Old 07-13-2013, 07:04 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Engine break-in is, what, 600 mi? Don't go over 4500 rpm? I'd do that if I were you.
Wear surfaces....
What happened to your turbos?
Old 07-14-2013, 01:48 AM
Mk23's Avatar
Frederic
I already do the cool down/warm up period when driving home and heading out.
Any idea how much an after-oiler costs? Until just now I had no idea they even existed.
Wear surfaces....
I'm at 300 miles now and already flogged it a few times, hope that is okay... Figured 300 was enough since at the time I hadn't gotten an exact number. Also, see below.
Old 07-14-2013, 06:44 AM
But why were they cracked?
OK, that's as outrageous as an IRS estimate o'taxes due. Guaranteed to strike fear in the very marrow of everyday citizens, IRS & its ilk have created and maintain the accounting profession. For that money they blueprint your engine.
Oh, and wastegate position can be manually adjusted; further adjusted in software. Without removing the engine.
Old 07-14-2013, 07:58 AM
Here's one. Bear in mind, you would have to plumb it into your turbo's feed lines. And then you need an extra quart of oil at every change.
https://www.cantonracingproducts.com...O-AFTER-OILER/
Basically, it's a can with a single opening on the bottom, and it's full of air. When you start the car, oil fills up the can, leaving a bubble of compressed air at the top of the can. When you shut down again, the bubble forces the oil back out of the can and into the turbos. A check valve ensures that the oil doesn't flow backwards into the engine.
The one I linked to improves on the idea by using a bladder, so it can be mounted in any position. But if you can weld up an airtight container, you can build the simple version that I described.
I plan to build and install one at some point. I just have to decide how to plumb it into the car, and where to locate it. I'm thinking that I want to mount it someplace cool, so that when the car shuts down, the turbos get a shot of cool oil to help bring their temperatures down.
Frederic
Old 07-14-2013, 10:30 AM
Zeichen311's Avatar
You do know the car's electric coolant pump circulates coolant to the turbos after the engine shuts down (when necessary), right? For a street-driven car an after-oiler is pretty much overkill.
Old 07-14-2013, 12:23 PM
sptt144's Avatar
Re: New turbos need a break-in?
The engine design explanation even says that it does this to prevent heat soak...I can hear it running sometimes after I shut down when its hot.
Sent from my SCH-I405 using BimmerApp mobile app
Old 07-14-2013, 12:46 PM
David1's Avatar
David1 David1 is offline
Mein Auto: 07 X3 and 335i
There is no break in needed for turbos.
2017 M2 - Alpine White - Black/Blue Dakota | DCT | Executive Package
2009 335i Coupe - LBM - Black Dakota/Glacier aluminum - 6spd | Nav | M-Sport | Premium | Logic7 | Heated Seats | CA |BMW Performance Suspension/M3 control arms| Sold
2009 X5 3.0 - Sold
07 X3 - Sold
07 335 coupe - sold
Old 07-14-2013, 01:46 PM
This is true. The water cooling makes a big difference, especially when combined with the electric pump. Even without the pump, water should circulate by convection if the lines have been plumbed correctly.
Frederic
