Old 07-12-2013, 12:40 PM
NFL Mark NFL Mark is offline
Mein Auto: 328i
Control Check Id Code 122
Noticed left front turn signal was not flashing, replaced the bulb, but light still doesn't work. What does the CC-ID 122 code indicate and what can I do to correct the problem? I appreciate any assistance offerred.
Old 07-12-2013, 02:03 PM
Ilovemycar Ilovemycar is offline
wooohooo
Mein Auto: '08 335i coupe 6MT sport
Gee I ran a search for that code, and yours is the only hit?! There is one other at the rest of the forum, but the title seemed to be off topic, and it was a huge thread. I've had the CC IDs for both sides, but only the rear taillights, and there the entire socket panel was so affordable, and easy to replace (mere seconds, no joke), I just went ahead and did both. (This was when the right side was the issue.) With the new ones installed, not long after I was futzing around with the left one for a reason I won't get into, and that's when I set off the left one. Weird. I replaced it with the old* one, problem gone. Not much help I realize, but that's one weird unrelated data point for you.
I wonder how much the panel is for the front, I'm afraid it's probably a lot more than the rear. I'm sure you checked all the connections, and probably used contact cleaner etc, if advised. I used contact cleaner at first on right rear, didn't solve the problem. (However the rears were a known issue before a certain build date.)
Keep us updated, and welcome to the fest.
Old 07-15-2013, 10:55 AM
Mein Auto: 328i
Spent the weekend playing with it; lloks like I'm headed to the service dept. Thanks for your response.
Old 07-15-2013, 10:57 AM
Mein Auto: '06 AW 330xi
CC-ID 122 is indeed the right, front indicator.
http://www.endtuning.com/ccidcodes.html
Do the side and rear bulbs hyper-flash? If no, then check the fuses.
Old 10-17-2015, 10:41 AM
Paarin1230 Paarin1230 is offline
Mein Auto: 2008 328xi
I am having the same exact issue. Error code CC-ID 122 which is for the right side, but my left blinker is not working.
What was your resolution?
