Old 07-12-2013, 01:43 PM
finnbmw's Avatar
finnbmw finnbmw is offline
Mein Auto: 2010 & 2012 X5 35d
Radio switching to FM 87.7 by itself at start-up
Happened today, went to to the post office listening to a local radio station (FM 95.5 for you living in Atlanta). When I powered up the vehicle to leave the PO, the radio had switched the station to 87.7 (1st available radio frequency). I think that this has happened before as well, just haven't paid enough attention thinking I must have bumped some button...
Has this happened to anybody else? What might have caused it? Thanks!
EDIT: This is the 2010 X5
Old 07-12-2013, 01:57 PM
Wardman Wardman is offline
Mein Auto: 2015 X5 35d
battery going bad? I used to have this happen with a shorted wire from my radio to the battery. It would reset all the stations - do the presets go away too?
Old 07-12-2013, 01:59 PM
BMW Power's Avatar
BMW Power BMW Power is offline
Mein Auto: 2012 X5 35d
This happens to me as well, I thought maybe it was because it was on an HD station and it didn't lock on the HD at startup and switched. It is very inconsistent and I have not noticed a pattern.
2014 i3 Rex
Retired 2012 X5 35d DSB - Prem, SAV, Cold, Sound, Tech packages, Apps Delivered 6/6/12
Retired 2011 335d AW, M Sport, Premium and Convenience pkg, Heated Seats, Nav, HK, iPod/USB, smart phone. ED 8/31/10
Retired 2008 335i Coupe 6-speed Manual, Montego Blue, Sport, Premium, CW, Nav, PDC, AS, Shade, HD, Sat, Ipod/USB, Logic 7, CA
PCD 11/07
Retired 2004 545i Sapphire Black/Black 6-speed Manual, Sport.
Old 07-12-2013, 02:21 PM
finnbmw's Avatar
I doubt it is the battery as it was changed a few months ago. The presets stay normal.
Yes, it is very inconsistent without a pattern. I was thinking there is some kind of software bug, but I have to check on your HD theory.
Thanks for the replies!
Old 07-13-2013, 06:21 AM
tony(topaz,SMG)'s Avatar
tony(topaz,SMG) tony(topaz,SMG) is offline
Mein Auto: '11 335i,'88 M3, '15 X5,
This happens in my 2011 335i with comfort access. No battery issues at all. Can't really figure out why it does this randomly.
Old 07-13-2013, 07:35 AM
yardbird yardbird is offline
Mein Auto: 2014 F15 X5 35i
My 2012 was losing the radio stations periodically and an engineer at the plant said it was a low voltage issue. The dealer replace a faulty battery ground cable and the problem has not come back.
Old 07-13-2013, 11:56 AM
gatorjaws gatorjaws is offline
gatorjaws
Mein Auto: 2013 x5 35d
If you have comfort keyless it probably because you used the other key? That's when it happens to me. I discussed it with the service dept. and their response was that the keys are not tied together. In fact they told me it wasn't a great idea to swap keys unless you have to. In other words programing for one key does NOT program the other so swapping keys is very hard on your electronics. At least that is the way it was explained to me.
Old 07-13-2013, 12:27 PM
finnbmw's Avatar
No comfort access on our X5's
Old 07-15-2013, 08:08 AM
BMW Power's Avatar
This isn't losing presets, the presets still work. It just goes to 87.7 when you start it.
2014 i3 Rex
PCD 11/07
Old 07-15-2013, 02:03 PM
gatorjaws
Thats exactly what mine was doing. I would use 1 key, then the other. When I went back to the first key the radio would be on the lowest channel and the mirrors would be out of adjustment. I didn't loose any presets either. Like I said I talked to the service people about it and they said it was swapping keys. Went home and tried it and viola, problem solved.
Old 07-15-2013, 02:35 PM
BMW_TX BMW_TX is offline
Mein Auto: 2012 X5D
This same things happens to me from time to time. I have not been able to determine what makes it do this. I never swap between keys.
Another electronic glitch that really bugs me is when you go into reverse and either side of the camera screen is blacked out so you cant see the sensor icon. This happens when I get into the car and start it using comfort access and quickly put the car in reverse SA said the computer needs more time to boot up.
Old 08-24-2013, 02:50 AM
WildcardHB WildcardHB is offline
Mein Auto: 335i Coupe
Same thing happens to me with my 335i with comfort access. Totally random. Same key fob. Told the dealer about it, but they said the electrical test came back normal and they couldn't find anything about it in their system. It's minor, but still pretty annoying...
Old 02-25-2014, 04:15 PM
Gilliam1 Gilliam1 is offline
Mein Auto: 2011 x5
Radio switches to AM
We just bought 2011 X5. The radio switches to AM everytime we start car. ??
Old 02-25-2014, 07:21 PM
nedchiu nedchiu is offline
Mein Auto: 2006 525Xi, 2011 X5d
The exact thing happens to my car. Inconsistently defaults to 87.7. The first time it happened was after a three day service (brake switch, replace rear seat etc). I thought perhaps the car was rebooted at the shop. I was driving the car home and I noticed a whining noise with a bit of static. The noise went a away after I tuned or switched off the radio.
Old 02-27-2014, 11:59 AM
frs1 frs1 is offline
Mein Auto: X3 3.0d
It is a low voltage problem, either earth or battery
Old 02-27-2014, 12:54 PM
the kidd's Avatar
the kidd the kidd is offline
pay it forward
Mein Auto: Subaru Impreza for now
This happened to mine after a repair for battery discharge. The battery was discharging most likely because of an issue w CD player. Only did it once
Present: 2013 subaru impreza with a great stereo!
2013 Honda Pilot Black/gray
2014 X3 msport carbon/chestnut
Past: 2013 X1 msport mineral/black (Takata)
2011 E90 M3 competition pkg Jerez/beige(i miss u so much)
2011 E70 35i titanium/black
2013 Subaru Impreza graphite/black
2011 E90 335i xdrive (bad mistake)
2005 Subaru Legacy GT
2002 Mini Cooper
Old 02-27-2014, 02:01 PM
henrycyao henrycyao is offline
Mein Auto: BMW X5 35d
This happens to me since I got the x5. Basically, this is only a problem if I start car at relatively short time after I parked the car. I figure it was caused by a software bug.
2012 BMW X5 Vermilion Red Xdrive35d with Premium Package, 3rd Row Seats, and Adaptive Drive
Old 10-02-2014, 06:16 PM
While I was research on this topic again, I found a post here that seem to suggest this can be solved by resetting the radio.
http://www.bimmerfest.com/forums/sho...d.php?t=764499
I am going to try that to see if it solves the problem. The dealer was unable to duplicate the problem today which I thought was reproducible if you power up and down within 5 to 10 minutes. Anyways, I wished I have research on this topic before bring up the issue with the dealer. Now my X5 is staying there overnight.
