The X5 SAV Forum
Old 07-14-2013, 01:02 PM
LantanaTX LantanaTX is offline
Mein Auto: 2004 BMW X5 4.4
Need help with power brakes and P2187
Hello, I am new here and just purchased a 2004 X5 4.4 I love the car and it looks like new. I got it cheap from a wholesaler because it has a few issues I am working through. A couple of days ago, the check engine light came on with P2187 (left bank lean) and at the same time the brakes got scary. The brakes at first feel fine but lose power assist before coming to a complete stop which means you really have to stand on the pedal to get it to come to a complete stop. I am checking out the obvious but wanted to see if anyone has ever experienced this and what the fault was. Thank you!
Old 07-17-2013, 05:23 PM
upallnight upallnight is offline
Mein Auto: BMW, Lotus, Porsche
Sounds like you have a vacuum problem at the intake manifold or booster. Check all the hoses for cracks.
Old 07-17-2013, 07:48 PM
I checked the hoses and also see that it does not get vacuum from the manifold like billions of other cars. it has a vacuum pump that runs of the right bank cam. The problem is either the pump or the booster. It isn't easy to know which part failed but I have read the pumps are prone to fail. with two new seals it can be rebuilt. I ordered the seals and will rebuild the pump. If that doesn't work a new booster will be next.
Old 12-18-2014, 08:40 PM
adriankiwi adriankiwi is offline
Mein Auto:
Hi there, did You solve the problem changing the pump, or did You change the booster aswell??? Many thanks
Old 12-19-2014, 10:50 AM
I did go through the pump and replaced the seals. That didn't do anything. I then replaced the booster and have great power brakes ever sense.
