The X5 SAV Forum
Old 12-18-2014, 02:37 AM
Macker1 Macker1 is offline
Mein Auto: BMW X5
Update on my X5 work
Hi Guys
Well, like i said in the last post, i bought a 2003 X5 3.0D a few months ago, absolutely loving it, Got alot of service receipts etc but decided id service it myself anyway, It had a wobble when braking at reasonably high speeds so i got myself some front discs and pads too, i went genuine BMW with the complete service kit and discs etc, cost me an arm and a leg but im glad i did it, i also fitted a removable tow bar at the same time
First things first, i am so glad i changed the auto trans filter and oil, its like a brand new box now!! so smooth
My brake wobble is about 90% better now, i wouldnt say its completely fixed, any ideas??
Couldnt believe how awkward the air filter was, very rare you see a pollen filter done in a fraction of the time an air filter is
And then of course the oul filter and a load of fresh Castrol oil too
So i really gave it the good treatment
Tow bar was a doddle to fit, v happy with that, then comes the goodies
I fitted a Bavsound bluetooth module, so easy to fit and a great little piece of kit, they were extremely helpful too
Now, onto the negatives, whilst carrying out the work, i found a CV boot ripped open very badly so that explains the notching im getting when turning/reversing, anything to note when buying and fitting one of these? its my front left gone
Also, my alarm, i have 2 dogs and quite often find myself having to leave them in the X5 for a while and i cant bloody lock the thing because they set the alarm off, is there anyway to work around this?
next, my dash shows temp in Farenheit, Anyway to change that to degrees celcius?
And lastly, my front window demister, is there anyway to just put that on a low setting instead of full power? when i press the demister it just auto goes to full power and if i knock it down a notch it just turns off? its an odd one but its bothering me......
Think thats it for now
Hope you guys can help with some of these and if anyone has any questions about the work i did i'd be happy to help
M
Old 12-18-2014, 09:18 AM
thrillcat thrillcat is online now
Mein Auto: 2005 BMW X5 4.8is
Farenheit/Celsius is in the menu system of your audio system.
To turn off the motion sensors, press the lock button twice when you lock it - the red light on the mirror will flash continuously.
That torn CV boot could also be causing your wobble. Replace the whole CV axle and you may kill two birds with one stone.
2008 X5 3.0si Alpine White
Old 12-19-2014, 02:52 PM
Damienreilly Damienreilly is offline
Mein Auto: bmw x5 4.6is
hi
yeah agree with the above
wobble could be a gone bush in the front or joint , x5 is heavy and will go through them quick .. jack front up an d check joint see what play is in the should be very little should be tight
the blower there is a thing called a hedgehog in behind the heater and these go on all BMWs easy to change , it a controller with a big metal heatshink on the back of it
cheap to buy and easy to fit 15 mins had to do it to mine
If CV joint is ripped defo this needs changed its normally filled with grease to protect joint which has been prob running dry for ages
