Lysol trick on the AC worked amazingly well - Bimmerfest - BMW Forums
Old 07-14-2013, 03:05 PM
MP3_E46's Avatar
MP3_E46 MP3_E46 is offline
Code/wrench Monkey
Mein Auto: Carefully
I'd swear the AC blows colder now. It's the coldest BMW air I've felt of the seven I've owned to date
This is an E93 I bought at 10.3K with a ton of issues (dealer failed to resolve most but I DIY fixed the rest and it's now almost at 15K miles with this being the only 'new' issue). Come summer we discovered this 'new' problem.. the AC stank badly. Recently it got too hot to drive with the top down so the AC has been used
I emptied about half a can of Lysol into the cabin vent intakes while running the AC on full. Since then it smelled of faintly lysol for a few days but otherwise it was ten minutes very well spent
This was a Miami car originally but we live in Atlanta. Presumably nasty things had grown on the AC coils before we bought it
Wonder what a dealer would have charged? Or if they'd have covered it under warranty... no way will I take back in unless anything major is wrong. The dealer broke both vanity light clips when adjusting the roof; after several emails I just ordered new ones and installed them myself. The kept falling out because the tech snapped the clips
Six Euro Deliveries since December 1998 (Owned E46, E90, E91, E92 and E93)
28 vehicles in 26 years of driving so far. Guess I like cars
Old 07-14-2013, 04:35 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Wurth used to make a non-scented aerosol for this issue with the bacteria on the coils. Maybe they stopped producing that stuff. Is there a non-scented lysol I wonder?
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 07-14-2013, 06:30 PM
MP3_E46's Avatar
Code/wrench Monkey
The one shown in my pic did not smell too much. Don't know which one it is, we had an almost full can in the house so I took it and used about half a can
It's super inexpensive and easy to find so IMO it's worth tolerating the residual smell for a few days than making the extra effort to find an automotive specific product
Saying that I instantly found one on Amazon for only $15 shipped: http://www.amazon.com/dp/B0002Z2MKO
Old 07-14-2013, 06:36 PM
llando88 llando88 is offline
Mein Auto: Ram 2500 4x4
Yes I've used that stuff, very effective.
I think it works better than lysol because it gets to the evaporator pan, but anything including lysol helps with the gym sock / barnyard odor.
BTW my SA at United BMW said if you turn off (all lights off) the recirc control on an E9x, the evap vent door opens at power off allowing the condensate to drain and evaporate.
Old 07-14-2013, 07:06 PM
bocabimmer's Avatar
bocabimmer bocabimmer is offline
Found the Search Button
Mein Auto: 2007 E92 328i, 2013 X5
That last part does indeed help... And not just on BMWs.
2013 X5 35i
2014 i3 BEV
2007 328i (E92) - BMW Performance exhaust, short shift kit, handbrake and steering wheel trim - CDV delete - CREE LED corona rings - LED license plate lights
2006 325i (E90) - SOLD - projector headlights - blackline taillights - satin grilles - shadowline trim - style 338 wheels
2000 ML430 - SOLD - heavily modded, I miss that truck
Old 07-14-2013, 08:39 PM
anE934fun anE934fun is offline
Mein Auto: 2010 335d
The evaporator drain is supposed to drain all the time. That is what the little drops of water on the road/garage floor/driveway mean. No drops = blocked drain.
Old 07-14-2013, 10:11 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
A common issue in AC drain pans: bacterial activity. Li'l ammonium quat + dispersant fills zee bill....
But does your evaporator route water to pavement? Could be partially or totally plugged!
Old 07-15-2013, 05:12 PM
MP3_E46's Avatar
Code/wrench Monkey
Leave puddles on the ground. I do wonder if it's partially clogged as the car's main rain drains were. Need to google sometime to find where it is and push a trombone cleaner/whatever fits up there
Fully clogged means water in the footwells for most car
