Old 07-14-2013, 04:16 PM
Blackedout335i Blackedout335i is offline
Mein Auto: 2007 BMW 335i
Alpina B3 6AT Flash
I've been seeing some posts around multiple locations about this being done. It is supposed to drastically improve up/down shifts with AT. But I can't seem to find out if it's a device or coding? does anyone have any other info on this? I feel like i'm running into a wall.
Old 07-14-2013, 05:02 PM
Mein Auto: '06 AW 330xi
It's a reflash of the transmission software. It's not coding.
Old 07-14-2013, 06:08 PM
Is this a hard process to do? I would love to do it, but I can't seem to find any in depth DIY on it.
Old 07-14-2013, 06:20 PM
A quick tutorial, or link to a descent DIY would be greatly appreciated! Any words of wisdom on the issue from experienced techs?
Old 07-15-2013, 06:40 AM
There is a diy guide on this forum and pretty much every bmw coding forum. There is even a video on youtube.
The process isn't hard but you have to setup winkfp correctly. Not doing so, you risk bricking your EGS module, which is your transmission module. You won't be able to shift into drive if you mess the flash up.
Old 07-15-2013, 06:50 AM
Alpina B3 6AT Flash
Oh wow, ok well ill make damn sure I understand before I attempt. Thanks!
