Old 07-14-2013, 08:49 PM
lamarselby lamarselby is offline
Mein Auto: 740 il
a screeching sound
whenever i push on the accelerator, i always hear like a screeching like noise coming from the engine..it normally goes away after the 2nd gear..could it be the serpintine belt
Old 07-14-2013, 09:19 PM
Podmore Podmore is offline
Mein Auto: 2001 BMW 735i
The screech is caused by a slipping serpentine belt; once the ancillaries such as alternator and p/s pump are run up to engine speed, the screeching will stop. Check and adjust the two tensioner pulley sets; if they are at full adjustment, replace the serpentine belt. Occasionally one of the adjusters will fail - check to see if there is still tension in the spring.
Old 07-14-2013, 09:29 PM
Mein Auto: 740 il
ok..how do i do that?
Old 07-14-2013, 09:52 PM
One belt tensioner is located just beside the water pump, on the right hand side of the engine. The other is accessible from underneath (remove the splash guard to get at this) and is just to the left of the crankshaft pulley (harmonic balancer). Have a look at this link:
http://www.bimmerboard.com/forums/posts/119957
Old 07-14-2013, 10:24 PM
Mein Auto: 740 il
ok.thnx
HTML code is Off
