The X5 SAV Forum
Old 07-30-2013, 11:44 AM
leehenken leehenken is offline
Mein Auto: X5
Two tire replacement
I was told I have to buy four new tires on my 2006 X5 or I will have transmission problems
Old 07-30-2013, 02:49 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Can you provide us with more of the story? We can surely give you the answer you want to hear (no)...but it may not be the correct answer...depending on why you were told this.
There's a HUGE leap in logic from being told to buy 4 new tires...to having tranny issues if you don't. It doesn't make sense without more of the story. Help us help you better.
Q {BMW CCA Member #191509}
(SOLD)
Old 07-31-2013, 03:32 AM
Scott ZHP's Avatar
We want the Lion!
This is a common tire store scare tactic on vehicles with AWD. They'll try and convince you that the center diff will be working overtime to try and correct for the different rolling circumference of the worn vs new pairs of tires.
Ideally, you dont want more that about 6/32 difference between the 4 tires. It really depends on the center diff and how variable it is to torque split biasing. The early E53 (without X-drive) used a fixed F/R torque split with an open diff; this is probably more tolerant of wheel diameter differences than the later X-drive, which has clutch packs to wear.
Old 08-06-2013, 03:45 AM
Hans Benade Hans Benade is offline
Mein Auto: 2006 x5 3.0 d
I have a 2006 E53 3.0d Sportpack and my car's transfer case actuator gave in.
I was told it was because the circumferences of the wheels differed to much, causing the actuator to work to hard.
I have wider tires in the rear and they wear quicker on the inside.
