Air con - Bimmerfest - BMW Forums
Old 07-15-2013, 10:40 AM
Jonjo Jonjo is offline
Mein Auto: 740i
Air con
Can anyone point me in the right way regards my 740i the air con not working the gas is charged and there's no leeks from the unit I was told it maybe the pump the pulley on the front is free any help pls
Old 07-15-2013, 03:05 PM
tim330i's Avatar
tim330i tim330i is offline
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
What year 740i? I will move your thread over to the 7 series forum so you can get more help there.
Tim
Old 07-15-2013, 07:31 PM
Mayorchuck Mayorchuck is offline
Mein Auto: '96 740iL
Is the compressor not kicking on? Blower motor not running? Here is a thread I am working on. You may be able to wade thru it for some help. Fuse 20 works the IHKA (control panel) and fuse 11 works the compressor.
Is your ambient temp on the cluster correct? If it's not working it will show -40 and the car will not let the a/c kick on if it thinks you are in Siberia.
http://forums.bimmerforums.com/forum...wer-motor-info
Old 07-16-2013, 12:04 AM
Mein Auto: 740i
Air con
Thanks for your reply ill look at these and report back thanks
Old 07-16-2013, 06:47 AM
Mein Auto: 740i
Ok so I have tested the 7-11-20 fuses they are fine the smaller fan in front of the main radiator is working.the pulley on the font of the belt driven pump is free .so what do you think is causing ac not to work could the pump its self be the fault thanks guys how can I send you pics of the instrument panel the temp is showing 16c both sides
Old 07-17-2013, 07:18 AM
Mein Auto: 740i
Hi when you say is the compressor not kicking in is that the part bolted to engine with a clutch wheel on front all I know when I start the car the temp is reading 16c and all lights come on for the air con when I'm looking from front of car with HUD up both fans are running I'm sorry but I don't know much on the ac
Old 07-17-2013, 07:29 AM
Mein Auto: 740i
Hello mayorchuck I had a look at the thread you posted and it cool but I don't think I can start taking the dash out and testing wiring sorry mate
Old 07-17-2013, 01:48 PM
The compressor/clutch are on that pulley as you described. When you hit the snowflake button below the panel, the compressor should kick on. If it is not, it is usually a low freon issue but not always.
But first, what EXACTLY is the issue? Is the blower motor/fan inside the cabin working but no cold air? Or, is there nothing coming out of the vents? There is no need to take off the dash if the fan is blowing air, warm or cold.
The ambient temperature (outside temp) on the cluster must be working also.
Old 07-17-2013, 03:42 PM
Mein Auto: 740i
Hi mate the blower is working fine ,but like you said its warm air coming through ,all cluster is working plus out side temp is fine , what is the low freon thanks john
Old 07-17-2013, 03:43 PM
Mein Auto: 740i
Old 07-17-2013, 03:47 PM
Mein Auto: 740i
Would you recommend I take it to my local garage to have the gas pressure looked at to be honest I was thinking of changing the belt driven pump or compressor
Old 07-17-2013, 04:25 PM
Mein Auto: 740i
Air con
Sorry if my messages are all over the place but hope you get this I have added some pics ,ok the fan blower is working fine the out side temp is showing in the panel it just blows warm air in car hope this helps thanks john
Old 07-17-2013, 04:34 PM
Mein Auto: 740i
Ok thank you mayorchuck thanks for al your help my friend best regards john
Old 07-17-2013, 04:39 PM
The freon is the 'gas' for the system. I noticed you AUC is on. I take it you have the same result while in the other settings? If so then yes, get the gas checked. It's the most common and easiest thing to check. They even sell it here with the gauges on the can but I would recommend taking it to someone with the proper gauges. If they find the gas if fully charged, they can check for power to the clutch and determine if the clutch/compressor is bad. My money is on low gas/freon.
Old 07-17-2013, 04:46 PM
Mein Auto: 740i
Originally Posted by Jonjo View Post
Ok thank you mayorchuck thanks for all your help my friend best regards john
. Yes I was trying with the other button on but the same result warm air coming in car
Old 07-19-2013, 02:53 AM
Mein Auto: 740i
Hi guys thanks for all your help I'm so glad you lot are on here saved me a few bucks or ..... I get the gas kit from my local store, the reading when I connected to ac was 0. Now all is well nice and cold in car now I can't thanks you enough best regards John
Old 07-19-2013, 05:24 AM
Well done. Thanks for the feedback.
HTML code is Off
