Old 07-16-2013, 08:46 AM
MikeinOH MikeinOH is offline
Mein Auto: 328i, 981S, RAV4
Plastic splash guard/skid plate damage on 08 328i sedan
I started to hear a rattling--especially when cold-- a few days a go from under near the driver seat--thought the exhaust system was coming off at first--but after I got under the car it appears the driver side plastic splash guard just behind the wheel well is damaged (pushed in a bit0 and the center splash guard under the oil pan is loose.
Does anyone know what type of fasteners are used on this and where you might get replacement parts if they are damaged too badly? Also, are there any schematic diagrams of this assembly on line--thanks for any help in advance.
Old 07-16-2013, 09:22 AM
Mein Auto: '06 AW 330xi
If I'm talking about the same thing, they use 8mm screws.
realoem.com
