07 328i - Bimmerfest - BMW Forums
Old 07-16-2013, 10:57 AM
neng1987 neng1987 is offline
Mein Auto: evo x
07 328i
Here is my problems, front driverside window will only roll up 3in at a time. No matter if i press/hold the button. Never had this issue before. I took the car out for a drive after sittimng for a month. For me to roll the window up/down i have to keep pressing the button.
Another issue is my brake light wont reset. I bought oem brake pads n sensor. I have follow the steps to resetting the light, but have fail.
Not to mention my warranty was up on july 12th 2013, Going to pay out of pocket.
Old 07-16-2013, 11:51 AM
Mein Auto: '06 AW 330xi
Try disconnecting your battery then reconnecting. That might solve the window issue. I believe the window does that after the anti-trap feature is tripped.
As for the brake light, you either aren't doing the procedure correctly or it's for brake fluid.
Old 07-16-2013, 12:41 PM
Mein Auto: evo x
Just try resetting the brake lights and it did resetted but still says 0 mileage till next change. I could live with the brake light on, not bothering as much as the window.
Going to give that a try. thnx, will post back.
Just try resetting, the one touch down was working but after 2 mins it went bad again. My idrive arent showing any message of anti trap?
I will try disconnecting the battery n resetting it again later.
Last hope is taking it to dealership
Old 07-16-2013, 01:43 PM
Is there any resistance? Maybe try with the door panel off. Something could have fallen in and is stressing the motor.
Old 07-16-2013, 04:01 PM
Mein Auto: evo x
Maybe, when window is fully close and i press up on the button it makes a cracking sound. I tested on the other three but no nearly as loud.
Can anyone recommend where to buy warranty now that my cpo is gone, its a 2007
Old 07-17-2013, 07:39 AM
I think your regulator is shot.
Old 07-17-2013, 12:10 PM
90rr 90rr is offline
Mein Auto: 2013 335i M-sport
Originally Posted by fdriller9 View Post
i think your regulator is shot.
+1
http://www.i35.photobucket.com/albums/d159/novak223/335i/222222_zpsxxm9xpwu.jpg
Old 07-17-2013, 12:30 PM
Mein Auto: evo x
Is that the signs of a shot regulator? Im hoping it could be resetted.
The window rolls up and down in increments. If it doesnt get solve after a few more trys, i will just get a new regulator.
Is oem better than aftermarket? If not, where should i order it from.
Old 07-17-2013, 12:37 PM
BiHoTTo115's Avatar
BiHoTTo115 BiHoTTo115 is offline
Mein Auto: 2006 330xi
http://www.oembimmerparts.com/BMW_E9...587-588e9x.htm
2006 330xi | 6AT | Navi | Premium | Cold Weather
