Old 07-16-2013, 10:58 AM
stevo89 stevo89 is offline
Mein Auto: bmw 740
Unhappy need help with my bmw 740ia limited edition
i found two purple relays underneath the dme that i think are blow they were in water soaked. so i got the water out. an underneath the seat was damp also one fuse was quite rust i fixed that but now i need to now what these relay go to much help would be apreciated the car turns over but wont start. NO SPARK ? but ithink im getting fuel ?is there a coil relay ? and somone give me a location please is there any grounds that i should check ? an when i change the relay it blows a fuse instantly ? any help please
Old 07-19-2013, 12:37 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Without a model year/build date info...you could have a:
  1. 1995-740iA w/M60 engine
  2. 1996-1998 740iA w/M62 engine
  3. 1999-2001 740iA w/M62TU engine
Help us help you better by creating a signature that includes your model, model year, and build date...or add that info where it appears in the upper right of your posts.
Q {BMW CCA Member #191509}
(SOLD)
HTML code is Off
