no spark on my 97 bmw 740ia - Bimmerfest - BMW Forums
Old 07-16-2013, 11:01 AM
stevo89 stevo89 is offline
Mein Auto: bmw 740
Unhappy no spark on my 97 bmw 740ia
there was 2 relays that were underneath the dme that were soaked in water idont think the dme was wet jus 2 purple relays which i need to know what they doo and abs relay. when i change the 1 purple relay it blows a fuse instantly so im wondering wats up an is that my dme relay ? pics and h elp would be much aprecciatied thanks
Old 07-16-2013, 11:02 AM
Mein Auto: bmw 740
it turns over fine good compression jus no spark
Old 07-16-2013, 02:02 PM
Mayorchuck Mayorchuck is offline
Mein Auto: '96 740iL
See my response on your other thread. Did not see this first. You need to pull the DME and make sure it does not look like this:
See post 3
http://forums.bimmerforums.com/forum...ror-code-P1637
I believe the purple relays are the wipers but your starter relay is down there as well.
Old 07-16-2013, 03:10 PM
Mein Auto: bmw 740
problems with my 7series
so i cleaned he silver relays up an found out 1 was too the winshield wipers which worked. before but now they dont . iwas checking the fuses and wires underneath the seat and i found 1 rusted so i clean that up and i found some wires heat were completely corotted an i cleaned em up hooked them back up and now i have no blinkers winshield wipers horn dosent work. odemetor coming on now ether i got a bit agravated and stopped working on it for a while. i checked all the fuses and none are blown. im still getting no sparks it turns over fine. no problems with the ecw. iknow theres a humming noice in my dme ichecked all the prongs they loook super good. im gona have to get a few pics of everything and have u tell me what you think . is there a coil relay ??? thats my big question . but im thinking it mite be a bad dme. becuase my parking light was constantly staying on before i messed with the corroted wires now it only comes on with the key but i have no odometor lights no horn no blinkers winshield wipers etc
Old 07-16-2013, 03:13 PM
Mein Auto: bmw 740
found out the dme relay is light green
the 1 purple one was the winshield wiper relay which worked perfectly until i messed with the corroted wires now i have none of that most the lights come up in the dash but gas gage isnt reading temp winshield wipers wont work blinkers wont work all after im tryed clean some wires underneath the passenger seat right next to fuse box
Old 07-16-2013, 03:18 PM
Now you need to check the General Module behind the glove box. If the passenger floor is wet, probably sunroof drain issue and it leaks behind, and often inside, the glove box. You are probably going to need this:
http://www.bmw-planet.com/diagrams/r...8old/index.htm
Old 07-16-2013, 03:23 PM
Mein Auto: bmw 740
ya i actually have the glove box off but i dont see nothing wet near the relays or anything... i did have alot of water just water underneath the dme near the three rleay and my whole rug is soaked right now im trying to dry it gona check the general module now if i can find it . now im getting a bit stumped hopefully i can get this.
Old 07-16-2013, 03:24 PM
Mein Auto: bmw 740
rug in passenger side near fuse box was wet so i am drying it
cleaned some corroted wires now things wont work im geting stumped...let see if i can find that module
Old 07-16-2013, 03:39 PM
Mein Auto: bmw 740
would the general module cause it not to start ?
HTML code is Off
