Old 07-16-2013, 04:26 PM
KSUTJH KSUTJH is offline
Mein Auto: 2000 540
Too many miles for JB4?
My car has about 82,000 miles and I was thinking of adding the JB4 mod, but I was curious if with that many miles if I would be asking for more rapid wear and tear on the motor? Any one have any ideas or experience? I dont plan on tracking the car, just want some more oomph.
Old 07-16-2013, 04:40 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
I'd get the heads checked for carbon buildup, check on the wastegates, turbos, spark plugs and if all good, I wouldn't se a problem. AS for wear/tear, the light that burns twice as bright burns half as long ...
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 07-17-2013, 01:54 AM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
Get the walnut blast, change your plugs, put in the JB4, and change your oil. Wazingggooo!!!! You should be good to go. Remember, you can turn this thing on and off from the steering wheel even as you are driving! I drive with it off most of the time until I feel "edgy", then I turn it on, let the oil warm up, and GRRRRROWWWWLLL I'm gone!!!
Old 07-17-2013, 04:05 AM
Teemo Panda's Avatar
Teemo Panda Teemo Panda is offline
Bimmefest Plasti-Dip Guru
Mein Auto: E53, E46-M3, E70, F25-X3
If you plan to alternate BMWs original specs on your engine, it will no doubt increase the wear.
Old 07-17-2013, 07:01 AM
King 5's Avatar
King 5 King 5 is offline
Send a message via AIM to King 5
Mein Auto: 1997 BMW 528i
Ive heard of guys romping on their 335i with a jb4 past 100k miles withoutany problems
1997 BMW 528ia 2/97
2004 BMW 330ci 4/03
2008 BMW 335i 3/08
Old 07-17-2013, 07:06 AM
Mein Auto: 2000 540
I am looking to probably go with Burger's oil catch can as well, in theory a lot of the carbon buildup should burn itself off if no more sludge is getting in there, but who knows.
Old 07-17-2013, 08:05 AM
TheyCallMeNun's Avatar
TheyCallMeNun TheyCallMeNun is offline
Fest Wrks
Mein Auto: 07 335i coupe
Its far from catching 100% but its a great starting off point.
Im about to be rounding 100K and was asking myself the same question OP. I did some homework and read that one of the biggest factors of FI and wear on these engine, is dependent on the compression. If engine compression is on target and the car isn't leaking, you should have a safe and pleasent experience. If you plan on increasing PSI on the turbos, you may want a compression test done first.
BMW Owner Since 17
'00 323i
'07 335i coupe
Black Sapphire 6MT
BMS JB+ & DCI
Turbosmart BOV
Old 07-17-2013, 08:37 AM
bear-avhistory's Avatar
bear-avhistory bear-avhistory is online now
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
If the car has any defects the JB4 will bring them to light. That being said most of the developer cars have a lot of mileage on them & get used a lot harder than customer cars.
Kevin
CURRENT:
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2014 BMW 435M-Sport MPPK/MPE 8ZF
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
470 WHP of BURBBLES
HOME FROM PAINT
