2006 325xi ENGINE LIGHT ON - Bimmerfest - BMW Forums
Old 07-16-2013, 04:02 PM
blue328i blue328i is offline
Mein Auto: 2000 328ci
I have a bmw 325xi e90 and the engine light is on. I check the codes with my new snap on scanner and it came up as oil level sensor and ambiant air sensor. Since the ambiant air sensor is not the culprit im guessing i need to replace my oil level sensor. I do not have any oil lights on i just have engine light. When i check my oil it says inactive. I was wondering if i put a used oil level sensor will it automatically start working and engine light go off or does it need programing. Please let me know thank you
Old 07-16-2013, 08:00 PM
would anyone know?
Old 07-17-2013, 06:38 AM
Mein Auto: '06 AW 330xi
It should be plug and play.
