Old 07-16-2013, 06:58 PM
HneDog HneDog is offline
Mein Auto: 1998 740il & 2010 750li
best way to lower 1998 bmw 740il e38???
im looking to lower the car about 1.5 inches and get a stiffer suspension. i was looking at H&Rs, they seem to be common but i just want to make sure i can get compatible springs for my project e38.
Old 07-17-2013, 03:37 PM
also how can i tell if i have a self leveling suspension or a sport suspension? (i dont have a sport model so i dont think i have a sport suspension)
Old 07-18-2013, 07:33 AM
umewes umewes is offline
Mein Auto: 2001 740i
KONI lowering kit.
Old 07-18-2013, 08:02 PM
wilk187's Avatar
wilk187 wilk187 is offline
2001 740il Sport, RIP
Mein Auto: 2006 750i Sport, '14 GTR
if your power steering reservior calls for "pentosin" on the lid (may have spelled it wrong...it's been awhile) and you have a button above the front cupholders that says "SLS" then you have self level.
Cold weather, PDC, BMW Ipod interface, Valentine1, MTecV2 Angel Eyes,
LED Lic. Plate Lamp, JL/Kicker sound, Bassknob, 21" Style 128's, 5mph autolock
Old 07-21-2013, 01:58 AM
i dont have the SLS buton is that mean for sure i dont have the self lowering suspension? (that would be amazing) if so i could get a fantastic stance setup!!!
Old 07-21-2013, 11:20 AM
wilk187's Avatar
even if you have SLS you can lower your 7...you just put in the struts and disconnect the EDC connections on the strut tower...i literally just cut the cable after i put new struts/springs on my e38..it (self level) isn't hooked up to the "Check Engine Soon" system
here's a pic of the cable..i cut it and put the dust cap back on top to keep the original look.
Old 07-22-2013, 02:58 AM
So if i cut that cable will i need to replace the struts or can i just use the aftermarket springs? i just dont want to mess anything up or i could buy the springs meant for the SLS but not get my favorite ride height
Old 07-24-2013, 09:07 PM
wilk187's Avatar
That is a good question...your car is a 98' so i'm assuming you need new struts anyway! I'm really not sure if you can keep the stock springs and cut the cable only..i put Bilstein struts on mine and changed the springs at the same time. It could potentially save you 300-400$, so i'd probably try it first.
Old 08-03-2013, 09:44 AM
StreetJeeper StreetJeeper is offline
Mein Auto: 1997 BMW 740i
You might wanna just go with coilovers. You can adjust it as high or as low as you want. A lot easier and better handling 100%
Old 08-04-2013, 09:31 AM
gheemer gheemer is offline
gheemer
Mein Auto: 740iL, Z4, 330i
my lowered 98 e38 740iL
I'm not sure there is a "best way" to lower your vehicle, just one that provides both the look and ride you want. Here's what I did and you can judge yourself. About 1" up front, just a little over 1" in the rear. Ride is slightly stiffer but still much softer than my 330 or Z4 with run flats.
I don't believe self leveling was available in 98.
Two before and after pics.
Eibach ProKit and Bilstein HDs - both from BAVAuto.
Looking for Mpars to replace the basketweaves next, then lower profile tires which will change the ride quality even more dramatically
Name:	2012-06-08 15.24.13.jpg
ID:	389702   Click image for larger version
Name:	2013-03-24 11.47.43.jpg
ID:	389703   Click image for larger version
Name:	2013-07-23 19.47.30.jpg
ID:	389704   Click image for larger version
Name:	2013-07-23 19.48.33.jpg
ID:	389705   Click image for larger version
Name:	Casa Gheemer Beemer.jpg
Gheemer
Old 08-21-2014, 02:36 AM
So i picked up a set of H&R stage 2s for 80 off my parts guy and was wondering could i put these on the stock shocks? obviously a 2in drop in front and a 1.3in drop in the rear will put more stress on the shocks but how long will the shocks last? i want to put them on the car and if the stock ones blow out ill either buy some bilstein HDs or sell the used springs and go for a coilover setup. MY MAIN QUESTION IS (knowing it wont be advised) how long could the stock shocks handle the lowered ride height?
1998 bmw 740il(current project) , 2010 bmw 750li
Old 08-21-2014, 06:24 AM
chrisn7 chrisn7 is offline
Mein Auto: 750iL
You won't find an SLS button in the car - self levelling happens automatically. If you have the wires to the struts, then you will have a button marked EDC (Electronic Damper Control) in the centre console switch centre, and the fluid reservoir cap will be marked Pentosin CHF 11S. Just to be clear, SLS and EDC are 2 completely separate systems. If you start cutting wires to these dampers this will be registered as a fault. Not certain but I think I read that they default to a 'hard' setting then. More on these at Tims site:
http://www.meeknet.co.uk/e38/EDC_III_Plus.pdf
Eibach do springs for EDC cars...
HTML code is Off
