Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners & Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great!
Old 07-17-2013, 12:29 AM
crom1 crom1 is offline
Mein Auto: e90
Exhaust smell inside car! What is this part? A lot of soot!
I have troubles with exhaust smell in my car when it's idling. Exhaust pipe troubles? Recently changed the turbo.
I took of the cover in my engine and instantly found this sooted part. What is it?
Thanks.
See attachment.
Old 07-17-2013, 05:49 AM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
What year and what engine is that?
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
Old 07-17-2013, 05:58 AM
Mein Auto: e90
Sorry..
E90 320D 2006mod, M47TU2D20 engine. European car.
Old 07-17-2013, 07:02 AM
floydarogers's Avatar
Pedant and Curmudgeon
According to http://www.realoem.com/bmw/showparts...17&hg=11&fg=40 it's the throttle.
Don't know why it's carboned up - might expect it of the EGR (which is the s-bend aparatus going down to the EGR cooler.
Old 07-17-2013, 09:02 AM
Blackedout335i Blackedout335i is offline
Mein Auto: 2007 BMW 335i
I had a similar problem with my 07 335i, the cabin would smell like exhaust. Started snooping around starting with the downpipes and found that I had a leak where the downpipes meet with the mid exhaust. You could have a leak anywhere when not moving, the smell creeps into your cabin.
Make sure you pipes are cool, and start your engine get under it and feel for any air escaping from where the pipes join. you're almost certain to find the issue.
PS. Clean that engine.
Old 07-17-2013, 09:21 AM
BB_cuda's Avatar
BB_cuda BB_cuda is offline
Mein Auto: 2011 335D Msport
There is some black stuff right there at the throttle body flap axis. See the stuff on the spring. I'm an ex smoker and glad i quit 25 years ago but a good use for a lit cigarette put close to suspected leak spots will possibly show leak points. I would start at that soot spot shown in the photo. I agree with Floyd. The EGR injection point is downstream of the throttle body. You may need to get a buddy to moderately increase throttle from the driver's seat while you are hunting with the cig. Good luck.
Old 07-17-2013, 10:12 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
I have just discovered that BMW turbos, maybe others too, are operated by exhaust gas!!!!!
As you've just replaced the turbos and exhaust smell appears to be coincident, well.....mmmmm.....
Hey this is no diesel forum! Have no idea what that part is. RealOEM drawing, your model?
Old 07-17-2013, 10:27 AM
Mein Auto: e90
Thanks for all your input, guys. Looking for leaks and loose clamps now!
While I'm at it, I'm gonna clean the engine as well, but I must admit that I'm a little bit nervous of pouring alot of water in there... I'm generally very strict with keeping my car clean, but not under the hood. Perhaps someone can tell me a bit about how to do it "correctly"? What to cover up? Hot water? Cold water?
PS: Mod: Please move thread to diesel forum.
Old 07-17-2013, 10:30 AM
BiHoTTo115's Avatar
BiHoTTo115 BiHoTTo115 is offline
Mein Auto: 2006 330xi
http://www.detailedimage.com/Ask-a-P...ur-engine-bay/
Here you go. I suggest using a good degreaser and scrubbing the gunk away on everything you see with a brush before shooting the place up with water. Powerwashers work well.
2006 330xi | 6AT | Navi | Premium | Cold Weather
Old 07-17-2013, 06:25 PM
There are tones of engine cleaning tutorials on YouTube, no need to run a hose under the hood scub brushes and degreasers will do just fine with some finesse.
Old 07-17-2013, 07:03 PM
That much oily soot on it would indicate that the throttle shaft is leaking, since it is a turbo, there is a fair bit of pressure there, so it doesn't take much if it is not sealed. The concerning part is he amount of oily residue as that came from inside the intake, meaning a lot of oil in the intake and the only place that can come from would be the turbo seals leaking. If this was like this before you replaced the turbo it would make sense if the old turbo was leaking oil, then you may just need to fix the seal issue on the throttle shaft, unfortunately it doesn't appear you can buy anything but the complete assembly for 400 bucks.
Guessing the exhaust smell is more likely a leak either at the manifold or downpipe and that will smell up the car.
Rob
Old 07-18-2013, 03:56 AM
finnbmw's Avatar
finnbmw finnbmw is online now
Mein Auto: 2010 & 2012 X5 35d
I bet your EGR cooler is cracked and leaking soot and exhaust gases. Do a search for "EGR cooler cracked" or similar.
Pretty common problem with the BMW diesels
Old 07-18-2013, 04:51 AM
You didn't look closely enough at the pic. The EGR cooler and line is pristine, and the soot is clearly on the throttle assembly.
Old 07-18-2013, 06:54 AM
Mein Auto: e90
I agree with you.
Can anyone shed some light on what the "throttle" really does here? I have searched around the web a bit and haven't seen anyone mention having problems with residue on this part. I think also the part is located at a different place in the compartment as i can't localise it on all the pictures I've seen.
roadkillrob: your thoughts regarding the turbo makes sense. I have now a completely new turbo installed and i will try to clean the throttle shaft up as much as possible and re-check for residue after some miles.
Old 07-18-2013, 07:10 AM
d geek d geek is offline
diesel evangelist
Mein Auto: Volvo V60+ Volvo S80
I agree with you.
Can anyone shed some light on what the "throttle" really does here? I have searched around the web a bit and haven't seen anyone mention having problems with residue on this part. I think also the part is located at a different place in the compartment as i can't localise it on all the pictures I've seen...
I think the "throttle" is an anti-shudder valve. These are used to shut the engine down smoothly by cutting off air immediately on shutdown.
Oil could be from the turbo or from PCV system.
I'd remove the intercooler inlet and outlet hoses and check for oil collecting there.
Old 07-18-2013, 07:41 AM
Also seems to be related to apportioning air mixture EGR versus "clean" air.
Old 07-18-2013, 07:44 AM
Hoooper Hoooper is online now
Mein Auto: 335D
or the other, more obvious and common place for oil to come from, the PCV
Old 07-18-2013, 09:49 AM
diesel evangelist
I was wondering about that, but the EGR inlet appears to be downstream of the valve- so I don't think that's the case.
Old 07-18-2013, 10:26 AM
Mein Auto: 335D
if that throttle valve closes, the engine should pull more recirculated air when the EGR is opened, so it could possibly be used for that effect. Anyone with a Bavtech tool should be able to check into that. Mine wont be up and running until tomorrow.
Old 07-18-2013, 11:48 AM
Mein Auto: '06 AW 330xi
lol all turbos are operated by exhaust gas. Superchargers are belt driven, hence little to no lag.
Old 07-18-2013, 01:40 PM
BB_cuda's Avatar
fdriller, Cal is super sarcastic but quite knowledgible on many topics. He has a "different" brand of humor [which i find to be funny]. His point is you just disturbed something and now a new problem exists. Go hunt there first. He runs a E93 N54 turbo gas burner. This thread was over in the "mainstream" 3 series section when he wrote but then it was moved over here with us where it belongs. Cal wrote a killer DIY on converting E9X over to M3 suspension (but not full 100%). He runs meth/water injection, or he once did.
Early in this thread, we didn't know the OP was running a 320D/European market.
@crom1, did the throttle assy get removed during the turbo work [EGR valve cleaning would require this]? What was wrong with prior turbo? Perhaps if it had low to no boost, the new turbo is now producing legit pressure to now blow out of that throttle shaft seal. Go get a buddy to rev the engine and put a smoke source [lit cigarette works like a champ] by the oiled up spring/shaft area. that is a quick and easy thing to do before digging down into turbo area where its so much more cramped.
my 2c
Old 07-18-2013, 05:23 PM
GeoX750Li's Avatar
GeoX750Li GeoX750Li is offline
Mein Auto: 2010 750Li X-Drive
Cal's post was hilarious! The "maybe others too" serves as both the tell and the punch line.
Old 07-18-2013, 06:45 PM
diesel evangelist
realoem.com shows the egr valve being the part that the egr plumbing goes to. A vacuum actuator is attached to the other side away from the inlet. This controls exhaust gas into the intake:
The device with the oil is shown as a "throttle". As we all know, diesels run on max air all the time and adjusts fueling- there is no throttle to control air in normal operation. I'm pretty sure this is just to stop the engine smoothly.
Old 07-19-2013, 05:25 AM
F32Fleet F32Fleet is offline
Account closed at users request
Mein Auto: 435i, 335d sold.
And prevent runaway.
Old 07-19-2013, 09:54 AM
Mein Auto: 335D
point was that the throttle could also be used to force the engine to pull more through the EGR than it would with that throttle being fully open. If the engine is not in boost then closing down that throttle a bit would force the engine to pull from the EGR more. Not sure if/how that would work under boost though
HTML code is Off
