Old 07-17-2013, 09:14 AM
nickolo nickolo is offline
Mein Auto: BMW 335i xdrive
Hand Brake Adjusting 101...
So...I read a post yesterday about how to take the slack out of my hand brake in my 2010 335i xdrive...seemed pretty straight forward, take hand brake boot off...release tension on the spring...remove a lug bolt from each back wheel and line up with adjustment hole and then tirn adjustment wheel until tight, but still be able to turn wheel by hand.
After adjusting each wheel I went for a ride...everything was great and the hand brake was never tighter and actually stopped the car immediately!! Thought to myself...You're good, JOY!!
NOT!!!
all of a sudden I started feeling a huge vibration after about a mile so I pulled off the road and my back wheels were ROASTING!! I could smell burnt brake material as soon as I stepped out of my car and the wheels were almost red hot!!
Moral of the story...remember when adjusting hand brake to take slack out of each rear wheel as mentioned above and then BE SURE TO BACK OFF ON THE ADJUSTMENT at least half a turn or more!!!!!
Crap!! Hope I didn't warp my rotors!!
Old 07-17-2013, 09:52 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
NOT!!!
Parking brakes on these vehicles are a "drum in disc" type, the rotors are fine, but I would examine the shoes used for the parking brake if possible.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 07-17-2013, 09:55 AM
Thanks, will do! Do I need a wheel puller to pull the rotor??
Old 07-17-2013, 05:04 PM
MP3_E46's Avatar
MP3_E46 MP3_E46 is offline
Code/wrench Monkey
Mein Auto: Carefully
Should always makes sure it needs a few clicks on any car
I adjusted my E93 to whatever the BMW spec is and it's still crappy. Finally holds the car in neutral though. Dealer said they adjusted it last time it was in for warranty issues and it still rolled in neutral...
If the rotors are warped you'll easily feel it through the pedal
Six Euro Deliveries since December 1998 (Owned E46, E90, E91, E92 and E93)
28 vehicles in 26 years of driving so far. Guess I like cars
Old 07-17-2013, 08:22 PM
thekurgan's Avatar
Bad Lieutenant
Rotors are NOT used for the parking brake.
Ilse
Bruna
BMWCCA #453648
Old 07-18-2013, 06:11 AM
Yes that's correct, rotors are not part of the parking brake system... BUT it looks like the drum used for the parking brake is part of (or connected to) the back of the rotor...or maybe they're 2 seperate pieces? I did not pull the rotor to look and confirm.
But believe me when I say...My rotors were almost red hot when I had the hand brake adjusted too tight!
Old 07-18-2013, 07:32 AM
thekurgan's Avatar
Bad Lieutenant
Heat can be caused by the conduction of the surrounding drum, not the direct frictional contact. I don't believe there will be any deposits on your rotors.
Now if you left the parking brake set, who knows, you can damage the shoes and they may need replacing.
Maybe these diagrams will help (courtesy penskeparts.com)
It is strange though, after 6 BMWs, I've never had to adjust the parking brake. Once per month, I come to a stop from 20 mph or so, using only the brake, to scrub off any corrosion from water/washing, etc.
ID:	387334   Click image for larger version
Ilse
Bruna
BMWCCA #453648
Old 07-18-2013, 08:29 AM
Yep, looks like 2 parts...the rotor itself and a drum behind it for the hand brake. I don't see any reason to ever have to replace the shoes or drum for the parking brake unless it was rubbing so tight it wore the material off the shoes.
In my case the heat transfer from the drum to the rotor was intense!
You would think that the parking brake would be self adjusting with springs holding the shoes against the drum but mine was clicking 10-12 clicks all the way up to the stop which was more than 45 degrees. Maybe the previous owner had brake issues? I have only owned the car for a couple months and it has brand new rotors, calipers and pads all the way around and brand new Micheline Sports too...saved me a few grand!!
Thanks for the pics!
Old 07-18-2013, 05:29 PM
MP3_E46's Avatar
Code/wrench Monkey
Correct
Old 07-18-2013, 05:31 PM
MP3_E46's Avatar
Code/wrench Monkey
Metal conducts heat well, I bet your wheels were really hot too. Years ago I had an E46 caliper seize and the wheel was hot to the touch
hand brake adjustment
