Old 07-17-2013, 09:55 AM
braymond braymond is offline
Mein Auto: 2008 335xi
No Sound in Car
I have a 2008 335xi, while driving down the road my music stopped playing. I have no warning sound, my bluetooth isn't working. but Radio is working fine, when I'm on a call it shows whom I'm speaking with. I've been told it could be the amp, but I was wondering if there could be anything else to look at before I start paying for an amp??
Help please!
Old 07-17-2013, 09:59 AM
fdriller9 fdriller9 is online now
Mein Auto: '06 AW 330xi
Fuses.
Check the amp compartment. If there is water in there, or any signs of moisture, there's you problem. Have that leak sorted. Then replace the amp.
Old 07-17-2013, 10:09 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Help please!
Uhhhhh, yeah, it could be something else. Was your Bluetooth link still connected?
Old 07-17-2013, 10:13 AM
Yes the blue tooth link is still connecting, I have to always change to my iphone when dialing a call.
Old 07-17-2013, 10:22 AM
You mean you can't dial through iDrive? You must voice or manually dial directly through you iPhone? Yet Bluetooth is connected?
Old 07-17-2013, 10:23 AM
@fdriller9 I have been looking in there frequently but havent noticed any water. I keep hearing its the amp I was just hoping to eliminate some other things before replacing.
Old 07-17-2013, 10:25 AM
Correct! I cannot dial thru idrive, even though it does show whom I'm speaking with on my radio screen. bluetooth is connecting. I have no warning chimes, nothing just stone silence.
Old 07-17-2013, 10:32 AM
