Old 07-17-2013, 10:52 PM
Leatherneck76 Leatherneck76 is offline
Mein Auto: 2007 530xi
2007 530xi seat belt alarm
is there any way in the setting to turn off the seat belt alarm ? It take about 3 mins to shutoff. Is there a way to shorten it maybe?
Old 07-18-2013, 06:32 AM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
The best way is to fasten your seatbelt. It dings 30 times and then stops.
There is no setting in idrive to shorten it, but the car can be coded to eliminate it and thats a whole other thread.
Old 07-18-2013, 08:42 AM
Mein Auto: '06 AW 330xi
You can have the car coded and have the chime removed.
Old 07-18-2013, 11:34 AM
Looks like ill get in the habit of using the seatbelt to the grocery store 2 blocks away
Old 07-18-2013, 11:53 AM
You can also buy a buckle and just leave it in the slot. But like boramkiz said, it's better to just use your seatbelt.
Old 11-15-2013, 03:13 AM
Bought some seatbelt clips from amazon, problem solved
