Old 07-18-2013, 07:25 AM
Jbump14 Jbump14 is offline
Mein Auto: 07 328i
07 328i brake problem
We have an 07 328i. It came time for rear brake pads so I ordered a set and put em on, everything went perfectly with no troubles. My wife was driving to work the next morning with the cruise on, ab halfway into her 1 1/2hr trip to work the cruise shut off and all the brake lights came on abs, brake light, etc. I rechecked everything and it all looked good, drove the car and it stopped no differently then before, actually better. Even changed the brake pad and speed sensors but its still on. Anyone had this problem or any ideas of what to check next?
Thanks in advance.
Old 07-18-2013, 08:07 AM
Mein Auto: '06 AW 330xi
Wheel speed sensor
Old 07-18-2013, 08:12 AM
Mein Auto: 07 328i
I changed it
Old 07-18-2013, 08:16 AM
There are 4. Check your battery too.
Old 07-18-2013, 08:23 AM
Mein Auto: 07 328i
I changed all 4, I was thinking that's what it would b so I changed em. The battery I've noticed First start up in the morning is a little slow but other than that seems normal.
Old 07-18-2013, 08:41 AM
You just changed all 4 on assumption? You didn't test them?
At least pull codes.
Old 07-18-2013, 09:35 AM
Mein Auto: 07 328i
What would be the best scanner for me to buy to read the abs codes, the scanners I have won't read it.
Old 07-18-2013, 10:35 AM
Bav tech tool or the coding cable and INPA setup. Or ISTA if you can manage that setup. Even DIS would work
