Old 07-18-2013, 11:07 AM
tetten tetten is offline
Mein Auto: X3 F25, Z3 Coupe 2.8
Z3 coupe height difference rear left and right
Hi,
This afternoon I discovered that the clearance the distance between the wheel and the rear wing differs with about an inch from left to right side. Broken spring or something more serious?
Any suggestions?
/Terje
Old 07-18-2013, 06:28 PM
Randy Forbes's Avatar
Investigative Tinkerer
On level ground, or could've a front wheel been on a bump?
Randy Forbes
2001///M Rdstr Steel Gray
Old 07-18-2013, 09:05 PM
Level ground - Rear wheels!
/Terje
Old 07-19-2013, 07:56 AM
Blacklane Blacklane is offline
Mein Auto: 1998 Z3 Roadster
Look for a broken spring. I found three broken springs on my roadster as I upgraded the suspension.
By the way, OEM springs are rather expensive and hard-to-find (at least in America). You should consider used parts, aftermarket springs (usually lowering), or a complete upgrade (such as coilovers).
There is a little more info here:
http://www.bimmerfest.com/forums/sho...d.php?t=688049
and there is a lot of info on springs and suspension here by using the "Search This Forum" button near the top right.
Old 07-19-2013, 06:25 PM
/Terje
A front wheel on a rise would have the effect of pushing the rear wheel on the opposite side up in the wheelwell.
I knew which end you were asking about!!
Randy Forbes
Old 07-20-2013, 05:18 AM
Old 08-07-2013, 02:16 PM
I put on a completely flat surface. I turns out to be 5 mm difference only.. and I did that after I ordered new springs... Special order and already arrived at the dealer. Couldn't cancel..
After 90k km it can't hurt to replace them. 550US including labor for OEM springs.
Old 08-07-2013, 03:54 PM
droz3 droz3 is offline
DROZ3
Mein Auto: 2001 Z3 / 2006 X3
I had the same concern with my roadster until I measured the dimension between the top of the lip of the rear fender to the center of the wheel (center of the roundel) and got the same dimension within 1/8".
I still see a difference when I look at the back of the car but my measuring tape saws otherwise.
Z3 2001 3.0L 5-speeds,Topaz Blue/Sport+Premium package/Stong-Strut/Bilstein shocks/Rogue Engineering RSM/Ireland Engineering rear sub-frame bushing/CDV delete/Conforti CAI/Jim Conforti Shark/DRL module/European Wiper Module/Pioneer AVIC-N4 GPS-Receiver+XM Radio+iPod/iPhone interface+Bluetooth+12CD Charger/ASA-AR1 18" wheels+Michelin PSS/Bi-Xenon upgrade.
Latest mod : 3.73 diff. ... WOW
X3 2006 3.0L Automatic, Silver Gray, all original ... so far ...
