Old 07-18-2013, 10:36 AM
westlafadeaway westlafadeaway is offline
Mein Auto: BMW 530ix
Shaky 535xi wagon
I have a 2006 535xi AWD wagon w approx 110k miles on it. Recently it has begun to vibrate over 55 mph or so (nothing heavy duty, but enough to take notice). We had a local guy look the car over. Wheels are balanced, transmission box looks ok, opened the car up and looked at a bunch of other things. He's a bit stumped. Before we take it to our dealer, any thoughts on this forum around this kind of an issue? I'd like to keep the car.
Old 07-18-2013, 10:44 AM
Mein Auto: '06 AW 330xi
Where is the vibration? Steering wheel? Seats?
Old 07-18-2013, 10:46 AM
It's the whole car. The steering wheel, drivers seat, passenger seat. It's not excessive but enough to trouble my wife.
Old 07-18-2013, 11:17 AM
tmcd535ixt tmcd535ixt is offline
Mein Auto: 08 535ix Wagon
Did you have the tires thoroughly inspected, not just balanced? Sometimes the tread can wear unevenly and cause vibrations.
2008 535 Wagon - Monaco Blue / Black - All the goodies plus JB4
Old 07-18-2013, 11:36 AM
Yes, he looked at the tires. The front tires are ok and in balance. The rear tires are worn and should be replaced. He recommended we replace the rear tires and put the new tires in the front but he wasn't convinced that would fix the problem. Transfer box is ok and the struts aren't leaking, which would be a bad sign.
Old 07-18-2013, 11:52 AM
Does this vibration occur all the time? Or only under load? ie accelerating.
If it's just under load, look at all the drivetrain mounts. Engine, trans, diffs etc
Old 07-18-2013, 11:54 AM
Good thought. It happens above 55 at steady speed (no acceleration)
Old 07-18-2013, 12:02 PM
Any noise? Maybe check wheel bearings? They normally don't cause vibrations though.
You can also check bushings an all arms.
Any worse when braking?
Did you have any service done recently, specifically with the wheels or brakes etc? Sometimes if you don't mount the wheel correctly, you will get a vibration. Happened to me last summer. I didn't mount my wheel correctly and over 90mph, my car would shake.
Loosen and retorque your wheels. If that doesn't work....have any friends with the same car? Try their wheels. If the shake is gone, you know it's either the wheels or tires.
FYI, a wheel and tire can balance perfectly on a balancing machine, but that doesn't mean it will stop vibrations.
You can also try moving the fronts to the rear and vice versa, granted you wheels/tire setup is not staggered.
Old 07-18-2013, 06:31 PM
Wagons_Rock Wagons_Rock is offline
Mein Auto: 535xit
bushings
Vibration @ 55 mph is quite common at this milage; check bushings; its an easy repair if that's the issue.
Old 07-18-2013, 07:20 PM
Munich77 Munich77 is offline
Mein Auto: 2014 E550 4matic
Thrud rod bushings?
2008 535 xi, space grey, black dakota leather, premium package, sport package, cold weather package, nav, folding seats, PDC
BMW CCA Member
Old 07-18-2013, 08:24 PM
Mein Auto: 535xit
Thrud rod bushings?
OK - thrust rod bushings ...
vibration problem, wagon
