Broken radiator cooling fan in my 535i - Bimmerfest - BMW Forums
Old 07-18-2013, 06:10 PM
DJtoad DJtoad is offline
Mein Auto: 2010 535i M Sport
I've been feeling a weird vibration the last couple of days and yesterday afternoon part of the cooling fan broke off while parked and idling with the A/C on. I didn't think it was a big deal at the time, I mean, how much can a plastic fan cost? Well, a lot. Apparently you can't just replace the fan, you need to replace the entire assembly, including the shroud and electric motor. I contacted Tischer / BMW of Silver Spring (www.getbmwparts.com) this morning and Evan got one pulled out of their local warehouse and had it ready for me to pick up by 3pm. Fantastic service as usual and even though it cost $620, that was cheaper than nearly anywhere else and I didn't have to wait a week or so for delivery.
I thought replacing it would be easy as well since everything I've read said it takes about 5 minutes to pull the assembly out of an E60. Well, not if you have a 535i since it has an oil cooler and the oil lines go through the shroud, something the Bentley manual fails to mention. It's not the first time I've found the Bentley manual didn't include accurate information on late model 535i / N54s. The procedure for removing the assembly is much more involved so I've decided to tackle it tomorrow AM instead of dealing with a hot garage and equally hot engine this evening.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
JB4 G5 ISO, BMS DCIs, ER Charge Pipe with Forge DVs, Proform Clear Bra, LUX H8 160 LED angel eyes
Old 07-18-2013, 09:37 PM
BMWalters BMWalters is offline
Mein Auto: BMW 535xi
DJ,
I feel your pain. I had to replace my shroud as well. My fan and motor work even though the plastic casing around the motor is cracked. I am going to replace the shroud around the fan and wait until I need to replace the fan and the housing.
I will be interested in how complicated or easy getting to the fan will be for you.
Old 07-18-2013, 09:54 PM
booyaazaa's Avatar
booyaazaa booyaazaa is offline
Mein Auto: Sputnik
Your car is a 2010, isn't it under warranty still?
E60
-Sport, Premium Package, and Comfort Access
-FBO, custom Cobb E45 map, Fuel_it Stg2 LPFP, Performance Gearing LSD.
Old 07-18-2013, 11:21 PM
dwlink's Avatar
dwlink dwlink is offline
Mein Auto: 435i Gran Coupe
Doh! (unless there's 50k+ miles on that car)
2015 BMW 435i GC MSport (ED Sept 29, 2014)
2004 BMW 530i (retired)
Old 07-19-2013, 08:51 AM
70K miles so no, not under warranty. It took a little over 2 hours to replace it this morning although if I had to do it again, I could probably get everything done in well under an hour. There are a number of hose support clamps that need to be removed from underneath and one screw that's a pain in the a$$ to get to on the back holding what I think was an A/C pipe bracket. The oil cooler pipes were no big deal. Just need something small to catch the couple of tablespoons of oil that comes out once they're removed from the cooler. Also, when removing the shroud, make sure not to tilt it towards the engine or oil from the mounted cooler will spill out and make quite a mess (ask me how I know!).
I'm pretty sure the fan cracked due to a mishap by the dealer last year but I have no way of proving it. An engine cover mounting bolt had fallen into the shroud and I'm sure it happened when they replace an injector a while back. I kept hearing an occasional rattling noise up front (sounded like marbles) but it wasn't consistent. One day last fall while parked on a steep driveway the fan made a horrible screeching noise -- the bolt had jammed between the shroud and fan ring. I was able to see it that time, managed to remove it, and the rattle disappeared. I'm sure it cracked the fan ring and the part finally failed completely earlier this week. The fan's been running at full speed at times since it's been so hot here.
Old 11-25-2013, 09:49 AM
Gee_115 Gee_115 is offline
Mein Auto: 550i
I am changing an alternator and I need to remove the fan. I was hoping you could give me some pointers on removing those lines. Specifically, the lines to the oil cooler. How many hoses, bottom and top?
Here is a post that I started, there was some confusion but your post clarified it.
http://forums.5series.net/e60-discus...-135900/page2/
Old 11-25-2013, 06:37 PM
The E60 Bentley manual makes no mention of the oil cooler so I was surprised just as you were when I encountered the lines passing through the shroud. There are only two (one in and one out) and the good news is that they are a piece of cake to remove from the cooler, at least on my 535i. If I remember correctly, each line seals using an o-ring and is held in by a single bolt. Once you remove the bolt, simply pull the line out of the cooler and drain the line into a small cup -- only a few tablespoons will come out. As long as you don't tilt the cooler, little if any oil will leak out of it. I left both lines connected to the oil filter assembly and just made sure the ends stayed higher then the assembly. In retrospect, I probably should have replaced the o-rings but didn't and have no leaks.
Old 11-25-2013, 10:21 PM
Mein Auto: 550i
Thanks. So after I remove the bolt that holds the line the entire fan cowling should just lift out?
Old 11-26-2013, 03:58 PM
I can't say for sure since you have a 550i and I have a 535i, but once I removed the top plate, various hose clamps and brackets that were attached to the shroud (some are only accessible from down below), removed the oil lines from the cooler, and disconnected the fan electrical connector, I was able to pull up and lift out the entire assembly. The oil cooler is attached to the front of the shroud so it comes out with it. You may want to plug the holes so that oil doesn't pour out while you're lifting it up.
Old 11-26-2013, 06:15 PM
Mein Auto: 550i
Appreciate the response. I did the alternator today. There were only two lines to remove, one at the bottom and one at the top. After removing those lines, you have to slightly lift the fan then fold in the tab on the driver side. You have to slightly lift the fan before folding the tab because that is the only way to get the tab to fold in pass the hoses. After folding the tab just lift straight up.
ID:	409599   Click image for larger version
ID:	409600   Click image for larger version
ID:	409601   Click image for larger version
Old 11-27-2013, 11:59 AM
Glad you got it done. The setup is a bit different than my 535i. Both oil lines are on the top (one on each side of the shroud) and there were no folding tabs.
