E30 (1982 - 1993)
Old 07-19-2013, 12:50 PM
E30panda E30panda is offline
Mein Auto: 1985 325e sedan
85 e30 fuel problem? Everytime I go up a hill or take a turn. Also while just cruisin
Everytime I go up a hill or take a turn. Also while just cruising fuel pump quits working even while directly wired to the battery. Nothing else shuts down bUT it will kick back in after a few seconds up to 30 min.
Sent from my SCH-I405 using BimmerApp mobile app
Old 07-19-2013, 05:03 PM
hornhospital's Avatar
D'oh, You Kids!
Re: 85 e30 fuel problem? Everytime I go up a hill or take a turn. Also while just cru
Put a fuel pressure gauge in the line near the fuel rail. Plumb and mount it so you can watch it from the drivers seat. Drive it and see if the pressure drops when the engine stumbles.
Sent from my MB860 using BimmerApp mobile app
Quotes to live by:
Old 07-19-2013, 09:54 PM
Its got new in tank pump new in line pump and filter. So i'm just really confused about why it happens. Also noticed when its cool outside it runs pretty well but during heat of the day its shutting off every mile or so. What exactly will the fuel pressure gauge tell me? What do I need to look for
Old 07-20-2013, 12:28 AM
toybuilder's Avatar
toybuilder toybuilder is offline
Mein Auto: 89 325i 2dr&DucatiMonster
Check the vent for the fuel tank . sounds like it may be clogged .in the heat of the day more gas vapors will build up making the problem worse.If your vent is clogged your in tank pump won't work properly .Also check the return line it can have the same effect on the pump .The other possibility is the filter on the bottom of the in tank pump is sucking up residue from the bottom of your tank.Did the car sit not running for any length of time? Most gas has ethanol in in these days and if you leave it in a tank without stabilizer in it it forms an alcohol/water bubble at the bottom of your tank.You can pull your in tank pump and see if the filter looks clean ,and look in the tank with a flashlight and see if it looks good .I suggest you also pull the fuel level sending unit from the other side of the tank so you can see both sides.Good luck ,happy hunting.
Old 07-20-2013, 12:41 AM
D'oh, You Kids!
You'll be looking to see if the fuel pressure stays steady, or if it drops just before the car dies. Then you need to determine if the pump is stopping or, as toybuilder suggested, if the fuel pickup is clogging.
Quotes to live by:
Old 07-20-2013, 12:55 AM
toybuilder's Avatar
Did you replace both fuel filters?
Old 07-20-2013, 06:48 AM
Sorry I am still pretty new to this. There are 2 filters!? If it helps any my in line pump whines extremely loud to where I can't even hear myself think. Am I able to check all this in tank stuff via the back seat?
Old 07-20-2013, 06:55 AM
The car did sit for a while the Man who owned before me claims to have dropped the tank and cleaned it along with replacing the fuel pump in tank.
Old 07-20-2013, 10:54 AM
D'oh, You Kids!
That's a VERY bad sign. A fuel pump that loud is dying or already dead. It should be almost silent.
Quotes to live by:
Old 07-20-2013, 01:05 PM
toybuilder's Avatar
There's a filter near the in line pump going to the engine and on the other side of the tank in the return line & if the pump is making noise it's either dieing or clogged.
Old 07-20-2013, 02:23 PM
See the in line pump is brand new replaced yesterday. There is a filter under the hood I have replaced. Was wondering where about the other one is I bet its the problem. It has tons of power just wondering why it shuts off out of no where. Especially on hills. Sounds like a filter problem? Also once i've been driving for a few miles it cuts out randomly
Old 07-20-2013, 03:09 PM
toybuilder's Avatar
Just look on the left side of the car it's either almost just behind the drivers door or closer to the fuel tank on the same side it may still have the plastic cover but you should still be able to see it .
Old 07-20-2013, 07:05 PM
Is this the other filter? never seen one like it before. Disregaurd the butt connector I was running a hot wire to make sure the new pump wasn't bad.
ID:	387691   Click image for larger version
ID:	387692   Click image for larger version
Old 07-21-2013, 08:10 PM
Could I just replace it with any canister style filter?
Old 07-22-2013, 08:41 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
You should then have 1 HVLP pump in the tank and this one you pictured being HPLV.
If the one in the Tank is supplying 3Bar at WOT full RPM, then you can just bypass the in-line pump you have pictured.
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
Old 07-22-2013, 08:58 AM
What is hvlp? I just need to know what that thing is so I can replace it
Old 07-22-2013, 10:46 AM
D'oh, You Kids!
High Volume Low Pressure.
Quotes to live by:
Old 07-22-2013, 11:33 AM
So what is that thing i'm pointing to
Old 07-22-2013, 06:13 PM
D'oh, You Kids!
It's a damping unit, to smooth out the pulses from the fuel pump. It is NLA (no longer available) an expression you'll see a lot. It has nothing to do with filtering the fuel. Just leave it alone.
Where are you in Alabama? If you're somewhat close I may be able to help hands-on. I'm between Mobile and Pensacola.
Quotes to live by:
Old 07-22-2013, 06:29 PM
That would be awesome! But i'm in pell city on Logan Martin lake. If the car would stay running long enough id meet you somewhere but...
Old 07-22-2013, 11:19 PM
D'oh, You Kids!
Yeah, that's quite a hike.
Quotes to live by:
Old 07-23-2013, 12:52 AM
toybuilder's Avatar
The filter for the return is on the other side of the car from where your looking .You'll see some fuel lines going back if you look along the drivers side just follow them back you'll find filter#2.
Old 07-23-2013, 04:32 AM
Everywhere I look besides the car says only one filter is on it but I will give it a shot. Not looking forward to a towing bill to the shop for them to fix it. ):
Old 07-23-2013, 07:14 AM
toybuilder's Avatar
It's under a black plastic cover that has a piece that sticks down like an mini air dam under the car but you should see the fuel lines running to it.
Old 07-23-2013, 06:34 PM
Do you think that is what causes the UN controllable vibration of the fuel pump and fuel line? Also the shutting off of the pump even while directly wired to the battery?
