Old 07-21-2013, 12:22 PM
pastman pastman is offline
Mein Auto: 2007 328xi
2007 328xi service indicator
Hello again Members:
My recently displayed "service indicator" (red car up on lift) icon adds the comment "brake pads at minimum thickness". My dash does not displace the front or rear brake pad warning. Is it possible that this is a mileage generated service light, rather than the warning from one of the brake pad sensors? Please advise. Thanks,
Alan
Old 07-21-2013, 03:18 PM
bocabimmer's Avatar
bocabimmer bocabimmer is offline
Found the Search Button
Mein Auto: 2007 E92 328i, 2014 i3
Does the red BRAKE light in the cluster that lights up when the parking brake is engaged stay lit?
2014 i3 BEV
2007 328i (E92) - BMW Performance exhaust, short shift kit, handbrake and steering wheel trim - CDV delete - CREE LED corona rings - LED license plate lights
2006 325i (E90) - SOLD - projector headlights, blackline taillights - satin grilles - shadowline trim - style 338 wheels
2000 ML430 - SOLD - heavily modded, I miss that truck
Old 11-18-2013, 09:08 PM
Daily Driver Daily Driver is offline
Mein Auto: 328i coupe
I had exactly this issue happen tonight. This morning the pads were at 50,000 miles for front and back and now the indicator is showing just dashes and a warning that my pads are done.
The red parking brake indicator stays lit.
I have a new battery, so it can't be that.
Anyone know if this could be due to??
Old 11-20-2013, 09:32 PM
anyone?
Old 11-21-2013, 12:30 AM
Banned
Mein Auto: 2007-335 HTC
well if you can take the left front and right rear wheels off, you can check the pad sensors and see if they are worn thru, If you cannot do this your self, a trip to an independent shop or the BMW place would be inorder
next if you dont have them, the bently shop manual would be a good investment and the Braverian tech scan too. if you get the scan tool you can read codes and with the bentley book you can figure out the problem
good luck
Old 11-21-2013, 01:54 PM
R1200 R1200 is offline
Mein Auto: 328XiT and R1200C
If a sensor wire is broken for some reason, the car would assume the brakes are worn out. More than likely they really are worn out. You probably still have some time as the pads were still OK when the light came on for us so not a panic situation but once the red warning light stays on continuously it becomes annoying enough that new pads should be installed. I changed rotors as well but that's a debatable topic.
Don
328XiT Sonora
