Old 07-21-2013, 03:02 PM
Momo1124 Momo1124 is offline
Mein Auto: 1998 bmw 328i
Loose hose.
I need a little help I found this hose coming from my engine and I have no clue where it should be connected to but I'm assuming its part of the air vacuum system. can someone help me out? The picture should be clear so it should be very easy to spot. And this is a 1998 bmw 328i
Old 07-29-2013, 12:25 PM
kpe42 kpe42 is offline
Mein Auto: 2000 328ci
A hose w/check valve like that often goes to the Air Conditioning system. Look for another loose hose at the fire wall. Also, if you still need help with this, you should post it with the E36 model threads.
Old 07-29-2013, 07:56 PM
BestCS BestCS is offline
Banned
Mein Auto: 2010 MB SLK & BMW 135i
It plugs into something. Shouldn't be hard to find. Run the engine with your head under the hood. Hear any hissing? Its length only allows it to reach so far. See what is within it reach?
Anyway it is probably part of the emission or crankcase ventilation system.
Old 08-03-2013, 05:27 PM
vt100 vt100 is offline
Mein Auto: 128i
Looks like it's a vacuum hose w/ non-return valve. Parts #6 and #7 here
Check the intake manifold - there should be a hose coming out of it that this valve was attached to.
Old 08-11-2013, 07:37 AM
Mein Auto: '06 AW 330xi
Looks like part of the SAP system but not sure if the E36 had a SAP system. The hose runs along the back of the engine to that valve you see in the diagram, #1.
If this hose has been disconnected for 2, consecutive cold starts, a SES light will illuminate.
