Old 07-22-2013, 08:15 AM
SDFarrell SDFarrell is offline
Mein Auto: BMW Z3 2.5 liter
Slight (unusual) brake noise
I just recently noticed a slight brake noise...kind of a grunt or slight grind...late in braking. It is a low noise combined with a slight crunch felt in the pedal, and it occurs just before the vehicle comes to a complete stop.
My pads are new all around. Could this be an issue of water or air in the brake lines? Any info would be appreciated.
As always, thanks. -Scotty
Old 06-02-2014, 05:49 PM
BillHopwood BillHopwood is offline
Mein Auto: 1999 Z3 Roadster
I recently bought a used 1999 Z3 that was well cared for by the previous one owner.
It has 48k easy miles and is in pristine condition.
But it came with this same annoying feature, a grinding brake noise just before dead stop.
It came from the right front wheel.
Fortunately, after much flailing, I found a simple fix.
After a round of swapping parts, which gets expensive in a hurry, I fixed the problem with my Dremel Tool.
I ground a 45 degree bevel all the way around the brake pad friction material. (Not the metal back plate).
I removed only about 1/16 inch of material.
Viola!! The annoying noise was gone!
Try it and good luck...
BillHopwood
