Old 07-22-2013, 11:28 AM
sandeepkarna sandeepkarna is offline
335ier...
Mein Auto: 335i 2009 AT sports model
Brake pads service
i got service due for rear brake pads showing 700 miles due on console , dealer said the thickness left is 6mm on rear and quoted cost of $650 for both pads and rotors(only rear).
is this price is reasonable or should i consider indy??
Old 07-22-2013, 11:34 AM
BiHoTTo115's Avatar
BiHoTTo115 BiHoTTo115 is offline
Mein Auto: 2006 330xi
Sounds horrific. Run away fast. Pads for rear, you can find between $90 and $120 or so, depending on if you want OEM or something aftermarket. Rotor are between $50-80 a piece, or so.
Big time rip-off. The rear sensor on the right side is also only a few bucks at most. The swap is incredibly easy, and should only take an hour at most with a good DIY found here:http://www.e90post.com/forums/showthread.php?t=473763
2006 330xi | 6AT | Navi | Premium | Cold Weather
Old 07-22-2013, 11:43 AM
Nerdboss Nerdboss is offline
Mein Auto: 2011 328i
$650??? Nope nope nope. Run away and don't look back.
Old 07-22-2013, 11:54 AM
bocabimmer's Avatar
bocabimmer bocabimmer is offline
Found the Search Button
Mein Auto: 2007 E92 328i, 2014 i3
Brake pads service
DIY for 1/3 the price. It's really not that difficult.
2014 i3 BEV
2007 328i (E92) - BMW Performance exhaust, short shift kit, handbrake and steering wheel trim - CDV delete - CREE LED corona rings - LED license plate lights
2006 325i (E90) - SOLD - projector headlights, blackline taillights - satin grilles - shadowline trim - style 338 wheels
2000 ML430 - SOLD - heavily modded, I miss that truck
Old 07-22-2013, 12:05 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Independent for a quote.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 07-22-2013, 12:31 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Way high - why noy DIY? Easy job.
Old 07-22-2013, 11:10 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
...mine is in the shop, I'd do it for free just to do something and show you how if you were nearby. If you have never done it, can be scary, but you can't mess up too much trying or taking off the wheels and checking it out. Typically about 2-3 bolts per side after taking off the wheel to get caliper and rotor off. Watch some You Tube videos on how to do BMW rear brakes. Will save you a LOT of money in the future!
Old 07-23-2013, 02:37 AM
Aaron1021 Aaron1021 is offline
Bring it to me and I'll do it for $600.
But seriously, take it to an indy if you don't want to do it yourself. For what it's worth, I think brakes are just about the easiest job you can do. Save yourself the money and do it yourself. Use the left over money from what you would have spent, and take the old lady out and treat her to a nice evening.
2009 BMW 335i
2007 BMW X3 Sport
2004 Subaru Impreza WRX (Sold)
Old 07-23-2013, 06:35 AM
Yo! Only $550 here + free coffee!!!
Old 07-23-2013, 07:28 AM
335ier...
i never did on my own , ill check with an indy and let you know.
Old 07-23-2013, 08:49 AM
fb88 fb88 is offline
Mein Auto: 2014 X1 xDrive28i
You don't need to replace the rotor if you don't have to. I only replaced the rotor on the 3rd set of the rear pad.
Old 07-23-2013, 12:01 PM
Westech's Avatar
Westech Westech is offline
Mein Auto: '00 Z-3 '06 325ixT
Time to learn. Do it yourself then enjoy the satisfaction of a job well done and the ton of saved money.
Believe me, it's an easy job.
Old 07-23-2013, 12:02 PM
BiHoTTo115's Avatar
I'd take the time to learn how to use a brake bleeder too (easy), you can get one from Bavauto for a few bucks, I'd recommend swapping brake fluid if you know it hasn't been done in 1.5-2 years. Make sure to pump those brakes though, or you'll get a nice surprise halfway down the road.
Old 07-23-2013, 12:06 PM
335IoTwnTrbos's Avatar
335IoTwnTrbos 335IoTwnTrbos is offline
Official 'Fest GIF Guy
Mein Auto: 2008 E92 335i
"When you can't run, you crawl... and when you can't do that, you find someone to carry you."
|100,000mile Club (E92)2008 335i SGM "Io"- Cobb Tuned |6AT|Premium|Sport|
|AE Performance CBE|AR Design DPs|CF GTR Vented Hood|Cobb AP V2|SP Lowering Perches (F)|M3 FCAs|VRSF 5" FMIC|
|BMS DCI|Niche Targa M129 18x8/18x9.5|BMS Spacers 10mm/15mm|BP Drilled/Slotted Rotors|BP Ceramic Pads|
|Forge DVs|CP-e Upper CP|VRSF Lower CP|BMS Cowl Delete|MR Front Strut Bar|BMS OCC|Custom CA License Plate|
Old 07-23-2013, 03:28 PM
Mein Auto: '06 AW 330xi
Go to an indy. Cheapest way is DIY. $650 is cost of parts for both front and rear including sensors and a brake flush, if you DIY.
Old 07-24-2013, 01:50 AM
sptt144's Avatar
Do you have any tools would be #1 question? You'll need some specific ones so that could cost you a little more but could start building your collection as well. Sears or local auto repair has what you need. You can ebay or Amazon and get some great deals on tools! Nothing is more satisfying then fixing your own stuff and saving $$$ to spend on yourself or significant other. And after a while, you'll be wanting to fix more yourself! Brakes are one of the best starting points to car repair. YOU CAN DO IT without anyone helping you. YOU TUBE search the repair like I said before and check it out. You can get the cheapest rotors and brakes at Autozone or online and worst case scenario if you don't like them is get better ones and do them again....and you'll still be under $650.00! I can do both sides tires on to start under 45 minutes! It may take you 2-3 hours the first time as you are seeing and learning. That's ok. Get a 6 pack. You need a jack and jack stands as well as the proper socket and wratchet to get those lug bolts out. After that, it is Chocolate Cake my friend! And after you are done, they won't hurt you or your car a tiny bit if you screwed anything up, which you won't! PM me and I will walk you through it! Or I'll call you! We're here to help. 714 321 9433 is my cell#. I don't get enough chances to help people or return favors so use me. You are here for help and guidance and we can give you that.
Steve
Old 07-24-2013, 01:58 AM
sptt144's Avatar
Attachment 388106
EXACTLY!!!! Some FREE-BURNT COFFEE IN A STYROFOAM CUP WATCHING Jerry Springer on the 13 inch TV/VCR Combo TV that just won't die!!! "Oh, and sir, we also noticed your air filter is dirty and your oil has turned brown (very dirty stuff)...you also have a PVC issue that needs replaced or you'll die while driving." "And. your transmission fluid needs flushed even though BMW doesn't even recommend it and we'll use the wrong stuff for you to make it even better!" ANYONE see the JIFFY LUBE Scams? Just try to fix your brakes. Want me to tell you what to buy and get? Let me know. I'm 2,500 miles away and can save you $450.00. Email or call me 714-321-9433 (Cell...text me if you want). Email is sptt144@aol.com
Steve P or "Stevo"
Old 07-24-2013, 03:45 AM
Banned
Mein Auto: 2007-335 HTC
second that, I just did my brakes, still had pad left but if you catch if before the sensor goes off you will save another 60 bucks, My rotors were still above min by about 100 thousands so I just pushed the piston back in and replaced the pads only, I figure BMW has a safety margin factored in the thickness too, I did take the calipers off and clean them up and paint them, They are Aluminum so be careful with them.
I have wondered why BMW has sensors since they recommend replacing the rotors everytime, unless is just to remind you to come in and spend some money
Old 07-24-2013, 07:40 AM
David1's Avatar
David1 David1 is offline
Mein Auto: 07 X3 and 335i
The sensor is there because people don't check stuff any more. Every day I here a car go by with no brakes left aka metal to metal scraping.
2017 M2 - Alpine White - Black/Blue Dakota | DCT | Executive Package
2009 335i Coupe - LBM - Black Dakota/Glacier aluminum - 6spd | Nav | M-Sport | Premium | Logic7 | Heated Seats | CA |BMW Performance Suspension/M3 control arms| Sold
2009 X5 3.0 - Sold
07 X3 - Sold
07 335 coupe - sold
Old 07-24-2013, 08:42 AM
Nooooooo! Self reliance -- [click here]
If you R&R brake fluid, which really is good on a yearly basis, [click here]
And Indy'll do the same, good stuff if you're unable to work on your ride. BUT! It is good to work with your hands, and to know your ride!
Old 07-30-2013, 08:54 AM
335ier...
Question
can i go with the pads below
http://shop.advanceautoparts.com/web...ke+pads+-+rear
and for rotors
http://www.******************.com/sk...3-1934700.html
Old 07-30-2013, 09:01 AM
Vanos4:12PM's Avatar
Vanos4:12PM Vanos4:12PM is offline
Mein Auto: 2005 e60 6sp black/black
How many miles on car - curious?
2005 530 6 speed/Sport/Prem/Cold black/black
2011 328i Sedan/6sp (lost to an accident and she is now at the big Roundel in the sky. )
1997 328i - gone "my first love"
BMWCCA # 367299
ED May 14, 2010
Old 07-30-2013, 09:05 AM
335ier...
its now on 37500
Old 07-30-2013, 09:23 AM
its now on 37500
Have the fronts been done yet? Not sure how long the rears should last but 37500 seems a bit early?
BMWCCA # 367299
ED May 14, 2010
Old 07-30-2013, 09:38 AM
335ier...
as per my BC fronts showing due for 17000 mi , and rears showing due for 700 mi.
