Old 07-22-2013, 02:41 PM
Lew Shaw Lew Shaw is offline
Mein Auto: 2005 Z4 3.0i Roadster
Front too low or tire too big?
I have a 2005 3.0i Roadster with sport suspension. Early on, I replaced the wheels and tires. I removed the front 225/40R18 Bridgestone run flats which had a diameter of 25.1 inches and mounted Hankook 225/45 ZR18's with a diameter of 25.9 inches, hoping the extra sidewall would give a much smoother ride. Well, the ride IS much smoother, but I have worn a hole in the wheel liner (both sides) at the top edge, right near where the bumper connects to the fender. So, I presume the clearance is not sufficient. Now, the question is, is there a way to raise the body slightly (1/2 inch) in the front ? If not, should I go back to a smaller front tire (225/40R18) or is there another option?
Old 07-23-2013, 04:59 AM
GeorgeT's Avatar
GeorgeT GeorgeT is offline
Mein Auto: '07 750i BMW; '03 Z4 BMW
You would have seen a dramatic improvement in the ride by just replacing the run flats with non-run flays of the same size. Go back to the original size.
Old 07-23-2013, 07:00 AM
imz4n's Avatar
imz4n imz4n is offline
Z ENTHUSIAST
Mein Auto: 06 3.0 si Z4R
I assume you are rubbing on the outer edge on both the left and right sides of the car or are you rubbing on both sides ( left and right turns ) on both sides of the car? You kept the rears the same as the RFT's?
Old 07-23-2013, 08:19 PM
Yes, it is rubbing on both the left and right fenders equally.
No, I replaced the rear 255/35R18 run flats with a diameter of 25.1 inches with 255/40ZR18's with a diameter of 26.0 inches which fill the wheel openings much better and also corrected the speedometer reading.
