Old 07-22-2013, 03:50 PM
medik621 medik621 is offline
Mein Auto: 1995 corvette
2007 328I hard start
Ok guys, I'm new here cause I've never owned a BMW but a friend has one, asked if I could
R&R his eccentric shaft sensor and plugs, no sweat I said as I am a mechanic, Accomplished the task in 5.5 hrs with no complications and no left over parts. Installed the servo motor per instructions, slid it in, allen wrench in the back, slowly corkscrewed it in, tightened her up. put the ignition fob in, foot off the brake, tapped the start button and heard the servo reset its limits. waited a few seconds and she started right up, now it has developed a hard start issue, engine cranks about 3 to 5 seconds before starting. Owner states this is new. No other problems at all, runs like a champ. All the coils tested within normal limits, no dash lights and no OBD codes. I did not remove the air box during service, there are no vacuum leaks, all grounds are properly attached and torqued. I am stumped, I"m obviously overlooking something but I'll be darned if I can figure it out.
Old 07-23-2013, 10:30 AM
You got to be kidding me
All you smart guys out there and not one suggestion!!
I must be an anomaly in that I am working on the only BMW that has or has ever had this problem. I feel special
Old 07-23-2013, 11:07 AM
Cool Fixed
Because I'm an adult and can admit when I screw up,
Went back over everything I did and viola, that sensor at the front of the head that inserts upside down, don't know what it does but, apparently the bolt must be more than hand tight. It was loose, torqued it properly and problem solved.
Old 07-23-2013, 11:12 AM
335IoTwnTrbos's Avatar
335IoTwnTrbos 335IoTwnTrbos is offline
Official 'Fest GIF Guy
Mein Auto: 2008 E92 335i
Good job man!
"When you can't run, you crawl... and when you can't do that, you find someone to carry you."
|100,000mile Club (E92)2008 335i SGM "Io"- Cobb Tuned |6AT|Premium|Sport|
|AE Performance CBE|AR Design DPs|CF GTR Vented Hood|Cobb AP V2|SP Lowering Perches (F)|M3 FCAs|VRSF 5" FMIC|
|BMS DCI|Niche Targa M129 18x8/18x9.5|BMS Spacers 10mm/15mm|BP Drilled/Slotted Rotors|BP Ceramic Pads|
|Forge DVs|CP-e Upper CP|VRSF Lower CP|BMS Cowl Delete|MR Front Strut Bar|BMS OCC|Custom CA License Plate|
