Nitrogen - not just for chem class anymore? - Bimmerfest - BMW Forums
Old 07-23-2013, 10:43 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Oh yes, oh yes, oh yes! The big Nitrogen debate!
Is it better than plain, common, FREE air? These folks think so....
Years have passed since I recommended moon based helium, or nitrous oxide, as excellent tire fills -- time to go back to "green cap?"
Old 07-23-2013, 10:53 AM
Banned
Mein Auto: 2007-335 HTC
mostly because shop air has moisture in it, and if the tanks are not drained regularly you could get a lot of water in your tires, which would only come into play in the winter when the water freezes in the tire and throws the balance off, till the tire heats up and the ice turns back to water.
if you know you have dry air, I see no benefit to other gases
Old 07-23-2013, 10:56 AM
Banned
yea I read the Bla Bla Bla, but since our tires last only about 30K miles its unlikely they will fall apart from the inside first
Old 07-23-2013, 11:01 AM
BiHoTTo115's Avatar
BiHoTTo115 BiHoTTo115 is offline
Mein Auto: 2006 330xi
That's why I fill mine with Chicken Soup.
2006 330xi | 6AT | Navi | Premium | Cold Weather
Old 07-23-2013, 11:10 AM
335IoTwnTrbos's Avatar
335IoTwnTrbos 335IoTwnTrbos is offline
Official 'Fest GIF Guy
Mein Auto: 2008 E92 335i
"When you can't run, you crawl... and when you can't do that, you find someone to carry you."
|100,000mile Club (E92)2008 335i SGM "Io"- Cobb Tuned |6AT|Premium|Sport|
|AE Performance CBE|AR Design DPs|CF GTR Vented Hood|Cobb AP V2|SP Lowering Perches (F)|M3 FCAs|VRSF 5" FMIC|
|BMS DCI|Niche Targa M129 18x8/18x9.5|BMS Spacers 10mm/15mm|BP Drilled/Slotted Rotors|BP Ceramic Pads|
|Forge DVs|CP-e Upper CP|VRSF Lower CP|BMS Cowl Delete|MR Front Strut Bar|BMS OCC|Custom CA License Plate|
Old 07-23-2013, 11:15 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Originally Posted by 335IoTwnTrbos View Post
... sums up this thread nicely .... must be a slow news day
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 07-23-2013, 11:17 AM
Old 07-23-2013, 01:57 PM
Mein Auto: '06 AW 330xi
On a racecar that is worried about lap times, sure. On a daily driven vehicle, you can do without it.
The nitrogen does help prevent fluctuations in pressure due to moisture expansion but it doesn't justify having to pay to fill your tires...
Old 07-23-2013, 02:43 PM
DSXMachina's Avatar
Bimmerdex 7.4!
I fill my run flats with nitrous oxide. That way when I get a blowout on the Cross Bronx Expressway at 5 pm on a Summer Friday I'll think it's funny.
Old 07-23-2013, 02:50 PM
BiHoTTo115's Avatar
Oh man!
Old 07-23-2013, 03:08 PM
Old 07-23-2013, 03:44 PM
thekurgan's Avatar
Bad Lieutenant
You're now the official Bimmerfest animated gif guy
Ilse
Bruna
BMWCCA #453648
Old 07-23-2013, 03:47 PM
I'll accept that role lol
Old 07-23-2013, 04:16 PM
Stevarino's Avatar
Stevarino Stevarino is offline
Mein Auto: 2008 335 / 2014 X-3
I'm already using nitrogen! At least 78% nitrogen that is.
The small amount of oxygen I lose due to osmosis I can easily top off with a bicycle pump when the tires are cold in my garage. A good quality bicycle pump is all you need for "trimming" the tire press. (Along with an aircraft quality tire pressure gage.)
Current Vehicles:
2017 440i Cv ED Sept 1, 2016 (ED #6)(PCD Oct 24)
2014 X-3 35i (PCD)
2008 E-93 335i Cv (ED #3) (Keeper)
BMW CCA #272524
Old 07-23-2013, 04:24 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Re: Nitrogen - not just for chem class anymore?
<bartsimpson>
I will not attempt to explain the Ideal Chicken Soup Law to Bimmerfest noobs.
</bartsimpson>
...I will wait for Zooks to do it.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 07-23-2013, 05:42 PM
+1 for Nitrous!
Naturally, when on Nitrous fill, one keeps a bottle in the trunk for top-offs. Also handy at Summer gatherings, this versatile gas is preferred by 3 out o'4 BMW pilots!
You Oregon residents! Is the Lighter Than Air Fair still a-goin' on?
Old 07-23-2013, 07:20 PM
Nordic_Kat's Avatar
Nordic_Kat Nordic_Kat is offline
(oO (||||) (||||) Oo)
Mein Auto: 2009 328i E93 MT
Originally Posted by CALWATERBOY View Post
+1 for Nitrous!
Truth be told, Someplace here on my hard drive, I have a pic of DSX's nitrous tank full of rarified air.
If your sport doesn't put blood, dirt or grease under your fingernails,
then it's just a game.
Euro Modded|Split Armrest|Rear Foglight Mod|BMW Performance Exhaust|CDV Delete|Shark Fin Antenna Delete|Front Reflector Delete|LUX H8 Angel Eyes|328i|3 Pedals|Das Fahren im Freien
Old 07-24-2013, 06:57 AM
BiHoTTo115's Avatar
Lmao, he speaks! Here I though he spoke only in GIF.
Old 07-24-2013, 06:58 AM
DSXMachina's Avatar
Bimmerdex 7.4!
I keep telling people, that was a fire extinguisher not a nitrous tank! My mad driving skilz to the contrary, I don't really go that fast.
Old 07-24-2013, 09:31 AM
Old 07-24-2013, 11:09 AM
Banned
so when they install your tires I am sure they do it in a Nitrogen environment free from oxygen, or do they vacuum out all the air to full vacuum and then pump back up with Nitrogen
so in reality your tires still contain AIR
Old 07-24-2013, 11:43 AM
3two8iguy's Avatar
3two8iguy 3two8iguy is offline
Mein Auto: 2011 E90 328i sedan
I wish that a sign was all that was needed to stop reckless driving,and to reckless drivers a sign serves no purpose.Might as well say "RUN YOUR NEIGHBOR OVER"...
Life is a Journey,Enjoy your ride.
Old 07-24-2013, 01:07 PM
///M-Furby's Avatar
///M-Furby ///M-Furby is offline
IntarWeb Stalker
Mein Auto: 2016 M3 SO ZCP
Wrong
Wrong
Right
"Tomato" ED 2016 M3 | B50 | ZCP | X3SW | ZDB | ZEC | ZLP | 2MK | 5DP | 6NS |
"Booberry" ED 2013 335xi | Returned
"Boo" CPO 2006 330xi | Sold
My Drive Style
Because I can.
Originally Posted by cwinter View Post
I agree with furby
Originally Posted by guerilla twang View Post
Hahahaha, I like you furb, you like to live dangerously.
Originally Posted by ProfessorCook View Post
I started to google to find a picture to match furby's suggestion to Gia, but it quickly became clear it was an inappropriate search to conduct at work.
Old 07-24-2013, 01:09 PM
Wrong
Wrong
Right
Why is comment wrong? Care to explain instead of just claiming it's false.
I was saying the moisture in air expands. Since nitrogen does not hold moisture, it isn't prone to the same expansion that happens with air.
Old 07-24-2013, 01:11 PM
